plastikdreams
- May 31, 2011
- upstate nj
If you can't rely on the ops to do a simple debur step...do you have a recording that lets them know when to breathe in and out?
If it was me I would be in the triangle file camp. But I'm actually OK at using files I think. Like two level passes and I think it would remove the burr and be done.
BUT, since files are out, how about a hybrid aproach. One of those pheumatic files from harbor freight, help in a vise, triangle file, on/off valve. Could the opererator be trusted to hold the part up level? (If you like the idea I would also clamp a little bar hanging our parallel with the file flat to give it some support when you push up against it)
I could just try the "here is a file, I will check your parts every cycle and yell at you until you get it right" approach...
I would like suggestions on which tumbling media to use for steels.
If I had that part and wanted to use one of the medias we already inventory it would be what we spec out as "ROSLER RX 5MM X 15MM S (ACT)." Rosler is the mfg and we get it from Advanced Finishing Technologies (Home - Advanced Finishing Technologies) as the distributor. It would probably be best to give AFT a call or send them a pic of your part so they can recommend a good media but it could be something like this:
So this might not specifically be cnc related, but wasn't sure if there was something y'all have come up with for something similar in the past.
I have a part made of stressproof material, about 2" OD and 1.7 ID. I am putting a 3/32 slit in it to split it so the ring can collapse.
I am running a 3" HSS concave saw blade, 200rpm 4ipm. "conventional cutting" so the cutter starts the cut on the ID and exits on the OD of the part.
I mount these parts 2 at a time on "arbors" that allow them to hang on top of the jaws, and the jaws clamp directly onto the parts.
Anyway, I am deburring the OD with a chamfer tool in the machine, but I am having a hard time deburring the ID. Currently using a 80 or 120 grit flap wheel 1.5" diameter in a die grinder. I have to do it twice, once one way, and then flip the part and go the other way. And even when I do that, sometimes I "miss" the burr, and gotta do it again.
The real problem is, while I trust myself to deburr these, I am not gonna run it myself, wanna put someone else on it but I have a hard time trusting anyone else to deburr their damn parts right lately (seriously, its been problematic of late). Anyway, I want something a bit more foolproof, while being quick and easy.
I am running 16 pcs at a time (8 arbors in 2 double vises), that runs about 8 minutes. 1500 pcs total at this time. I don't expect the operator to beat that time while loading the next set of pins, but if they were able to deburr and load pins in about 12 minutes, that'd be great (we've run these many times before, only now after years of running have I changed the setup to include deburring!!! lol...)
Slight additional challenge, parts are not super round after slitting, sometimes springing in .030" at the slot, can't really hone them. and surface finish is important, must be 63 or better.
Have tumbler, our media sucks, so if suggesting to tumble, what media would you use? ours just turns our parts muddy, hard to clean off, and just really doesn't do a good job cutting.
Was thinking about some sort of "deburring wheel" like the ones we use on our pedestal grinders, but I don't see them that small?
Was also thinking of trying to slit it with a slightly smaller tool then come back with the 3/32 but don't know if that would work or just cause more grief.
I'm open to suggestions, thanks
Notice
