dsatchell
- Oct 24, 2022
Hi ,
My FP2 (1970 version) has an extremely stiff quill. Based on a other posts, I've soaked it in penetrating oil, and removed the spindle unit (quill and spindle). I've check the locking lever, (it is working fine), cleaned out the interior with spray lube (not much grit there). After cleaning out the head, I placed the quill back in and the tightness is apparent as soon as the quill is put back into the head casting (first mm or 2), I needed to use a screw press to push it back in (making sure it was aligned with the key).
So now that it's back in, I have no difference in how stiff it is. I would guess that is takes about (maybe more) 10 to 15 lbs, on a 8" lever to move it (up or down). When I engage the locking ring, it feels almost the same (as if it's not making a differentce, but when the quill was out, I can feel that the locking ring is functioning (tightening and loosening).
I'm thinking that the fit is not correct but before I disassemble it again, I'm wondering if maybe this is what it is supposed to be.?
The head is definitly beat-up relative to the rest of the machine whcih is in very good condition. I suspect that the seller swapped out parts, and was wondering if maybe the quill/spindle was switched and therefore is not a matched fit.
Thoughts and guidance would be appreciated.
