Peter from Holland
- Jan 15, 2005
- The Netherlands
I bought a late model Deckel FP3 with active DRO TNC 113 abroad
I fried the DC motordriver trying to get it going on 400volts
It turned out to be a 220volts 3Ph machine
And that is a major PITA over here
I even sold it before I noticed (just a couple of hours on sale)
So now I have to change it to 400Volts 3Ph
Transformer 220/400 volts is out of the question because I got the full amount for it and then thinks have to be done the right (Deckel)way
First had to have the DC motordriver fixed
The shop who did that told me it had too high voltage and therefore som resisters blew (Very good shop BTW, glad to have that one arround)
Thats when I found out of it beeing a 220volts 3ph machine
The first thing we noticed was the spindlemotor had to be rewired for 400volts That is a 2 speed Dahlander motor so you cannot change it from
Delta to Triangle
The DC driver was fed with 2Ph 220volt between the 2 phases
So we figered out 1 phase 220volt and Neutral would do the trick too
Well that is not the case
I had a DC technician in house for some other stuff today and he told me
the transformer who fed the DC drive had to have 2 phases incoming
(The DC drive being a 4 quadrant and that was needed to stop the feeds within 0,05mm )
So now I have to get a new transformer to
Good news for all of you is, I now have a transformer 220volt for the DC driver for sale
Peter
Delta to Triangle
Peter
