Peter from Holland
- Jan 15, 2005
- The Netherlands
You have 40um scales and 20um scales And also readouts for 20um or 40 um only So check what scales you have to be sure your Dro will fit
Peter
Peter
Thanks for letting me know. I probably would not have realized that and gotten the wrong unit!You have 40um scales and 20um scales And also readouts for 20um or 40 um only So check what scales you have to be sure your Dro will fit
Peter
I have the stock heidenhein scale in X and new accurate for y and z. Accurite is made by heidenhein now. I had to buy a signal converter to make it work, so far no issues. The active system would be neat to have but maybe not worth the efforts.Thank you for the help! It does have the controls cabinet luckily.
I’m sure I’ll need some help once I get it. The plan as of now is to get another heidenhein dro unit and just use the machine with the power feed and dro. I don’t think I need the other features and maybe I can keep an eye out and buy an original control some day.
Very excited to get the mill as it seems to be a very nice unit.
I am thinking that the ND 750 would be exactly what I am looking for. I don't need rotary position. A 2038 "Tool Makers Table" sounds pricey as well This machine is already more than I need. A clapped out Bridgeport would probably do me just fine but I love nice machine tools so here I am.I would opt for a nice ND 750 or if you want to really go forward the second gen Positip readout.(850 I believe) That would give you the ability to display angular moves (4th axis)
should you ever find a 2038 "Tool Makers Table" That would be the one that has a Heidenhain encoder on the table rotary position....Angle and rotate would make that FP3 a real "do anything" jewel.
For my money that is a better choice to invest in over making the "Active" function on that FP3.
That is a real 3-D contouring machine, not a simple point to point arrangement as you would have with with a restored "Active" setup....
I'll just wait until I get the machine to figure out what I need. I will also make a new thread since this one has served it purpose and I bought the machineA ND750 can switch between 20 and 40Um IIRC
Look up the scale type and then look in the manual on their website if it is 20 or 40Um
Here at least you can download the manual for the VRZ775
To me it seems the VRZ775 is a 20Um and reads correctly with the LS107 -LS403 LS404- LS703-LS704 or these ones with a C behind it
But make sure to check it yourself
It can handle 40Um scales too but it dubbles the distance then
Peter
Thanks for the advice. I have put a deposit down and the guy gave me 4 weeks to come get it since I am a good 500 miles away from the machine. I am redoing my trailer and should be done this week so I think I will be getting the machine next weekend. I am very excited to get it. Should be an awesome mill to use.Just saw this thread. From the looks of the machine, from what you have written, and from the price, I can only repeat what Peter has already written: BUY BUY BUY
The "rule of thumb" in Germany, where these machines are quite common, is that if the X-axis backlash is less than 1mm, then the machine ways are probably not worn out. The 0.15mm of X backlash is very good, and you might even be able to reduce that a bit by adjusting the preload of the bearings at either end of the lead screw. If the axis are smooth and the spindles run true and quiet, then you're all set.The mill looks to be in very good shape after the initial inspection today. The ways seem to be in good shape and everything is very smooth. About 0.15mm backlash on x and y which seems very good. Nothing seems broken besides the handle and shaft end.
I think you are right about this. I was looking a bit closer today and the extra 9 pin connector does not look like it came originally with the unit. It is just zip tied to the other cable sleeves and goes off somewhere in the knee. I wish this table was still with my machine. Looks sweet!Pretty sure that the TNC 113 has only three inputs. (3 axis)
That machine might at one time have been fitted with the 2038 "Tool Makers" table that tilts and swivels in two directions, plus has table rotation via handwheel.
That rotation is usually (not always) fitted with a Heidenhain rotary encoder that directly reads out the table rotation ....Machines so fitted need an additional DRO (1 axis)box to read the rotation....Note not all Heidenhain DRO's are capible of displaying rotary degrees of rotation.....
I would trade that angle table on your machine with a 2236 table in a hartbeat if you were closerI think
Yeah I would assume I just need the universal table since it can do everything. The Netherlands is a bit of a ways away though.I would trade that angle table on your machine with a 2236 table in a hartbeat if you were closer
Peter
Notice
