I tried switch the motor wires and the tacho wires but that did not seem to fix it.
The blue wire #4 in the bottom left terminal blocks seems like it should be hooked to something but it is not. It was hooked to the 5 wire power cord that it was originally wired to but the blue wire did not go anywhere in the plug it was just a cut end.
Block 1,2,3 and 5 are where the power and ground were hooked to.
Also there is a short loose wire sticking out of the #9 slot of the block that connects the machine to the electrical cabinet.
Not sure if these clues are useful but that’s all I can see on the surface.
