Joe DMG
- Nov 6, 2003
- Schaumburg, IL, USA
We are proud to announce DMG Used Machine Division's first annual OPEN HOUSE in the first week of May! (Tuesday, May 3rd - Friday, May 6th) We will have several machines on display.
A few highlights will include a $9,500 Value raffle of a 1986 Maho MH800E CNC Universal Milling Machine we are giving away for FREE! (Winner must have attended the open house).
Plus, a 5% DISCOUNT of the purchase of a pre-owned machine at the open house.
Call me for more details!
Kind Regards
Joe
Joe Anselmo
Area Sales Manager
DMG Chicago, Inc. Used Division
Phone (847) 781-0277 ext. 244
Fax (847) 781-0388
Cell (224) 595-2272
www.dmgamerica.com
email: [email protected]
May 2005
DMG Used Machine Division Chicago Inventory List (pictures available for all machines)
- ask about financing - trade ins -
LATHES
064035 2000 Gildemeister CTX400 S2V3 with Full C-Axis capability, Fanuc 21i-TA (Demo machine!)
Bar Capacity: 2.56"
Max Chuck Size Possible: 10"
Z Axis Distance Between Centers: 25"
Speed Range: 25-5,000 RPM
Number Of Tool Stations: 12
Chip conveyor, Tailstock
Machine is a factory overstock, 68 actual power on hours total!! (never installed at a customer)
064004 2003 Gildemeister CTX400 S2V3 wtih Full C-Axis capability, Fanuc 21i-TA (Demo machine!)
Bar Capacity: 2.56"
Factory overstock, machine is new
064037 2001 Gildemeister Twin 32Y V6 Twin Spindle Twin Turret Y-Axis CNC Lathe, Siemens 840D Control
Machine has 9 programmable axes
Operating Range:
Sign Diameter: 5.7"
Turning Diameter: 3.9"
Spindle Distance: 22.8"
064082 2004 Gildemeister NEF 520/1000 Lathe, Siemens Touch Screen Display with Navigator Control (Factory overstock!)
Speed Range: 8-3,000 RPM
Working Area ---
Swing Diameter Over Guideways: 500 mm
Swing Diameter Over Transverse Guideway: 285 mm
Centre Height: 1000 mm
Transverse Stroke: 260 mm
064083 2004 Gildemeister NEF 520/1000 Lathe, Siemens Touch Screen Display with Navigator Control (Factory overstock!)
Working Area ---
Tranverse Stroke: 260 mm
064076 2000 Gildemeister CTX400 Serie 2 V1 2-Axis CNC Lathe, Fanuc 21i-TA
Bar Capacity: 2.56"
Chip conveyor, Tailstock, Interface for bar feeder, Parts catcher
HORIZONTAL MACHINING CENTERS
064057 2002 Deckel Maho DMC50H Horizontal Machining Center, Siemens 840D Control
X = 22" Y = 22" Z = 20"
18,000 RPM
CAT 40
Number Of Pallets: 2
Internal Coolant Supply Thru The Spindle Middle
Laser Tool Measuring of tool length & diameter, Also Broken Tool Detection
Only 99 ACTUAL Spindle On Hours!!
Only 1,650 ACTUAL Power On Hours
Machine was originally built: 1/30/02
First installed: 4/1/04
UNIVERSAL MACHINING CENTERS
064060 2004 Deckel Maho DMU70 eVolution 5-Axis Machining Center, Heidenhain iTNC 530 Control (Factory overstock!)
X = 29.5" Y = 23.6" Z = 20.5"
18,000 RPM
CAT 40
32 ATC
Production Package Consisting Of:
580 PSI (40 Bar) Coolant thru the spindle with needle slot screen, chip conveyor, air purge for linear measuring system, rotoclear window,
Renishaw MP 10 infrared measuring probe, Blum Laser Broken Tool Detection & Measuring of tool length & diamter
VERTICAL MACHINING CENTERS
063886 2000 Deckel Maho DMC65V Gantry Style VMC with 1G Acceleration, Siemens Sinumerik 840D Control
2,193 Spindle On Hours Total
X = 25.6" Y = 19.7" Z = 19.7"
18,000 RPM
SK 40
60 ATC
Equipped With -
580 PSI Coolant Thru the spindle, 206 Gallon Coolant Tank, Chip Conveyor, Visiport Inspection Window,
External Air Blast Cooling thru 2 pipes selectable by M-Function or Softk Ethernet Infterface
064048 2000 Deckel Maho DMC65V Gantry Style VMC with 1G Acceleration, Heidenhain TNC 430 Control with Electronic Handwheel
18,000 RPM
CAT 40
30 ATC
Equipped With -
Heidenhain Linear Glass Scales Direction Measuring System - All Axes, 580 PSI Coolant thru the spindle, 206 gallon coolant tank,
chip conveyor, Visiport Inspection Window, Laser Tool Measuring of tool length, diameter & broken tool detection, External air blast
cooling through two pipes, selectable by M-Function or Softkey (coolant or air selectable), Ethernet Internet for Heidenhain TNC 430 Control,
5-M Functions (TNC)
064021 2000 Deckel Maho DMC65V Gantry Style VMC with 1G Acceleration, Siemens Sinumerik 840D Control
18,000 RPM
SK 40
60 ATC
Equipped With -
580 PSI Coolant Thru The Spindle, 206 Gallon Coolant Tank, Chip Conveyor, Visiport Inspection Window, External Air Blast Cooling
064100 2000 Deckel Maho DMC63V Vertical Machining Center (DEMO! - Like New Condition, ONLY 109 Power On Hours TOTAL!), Fanuc 180i-MB 3-D CNC Control
X = 24.8" Y = 19.7" Z = 19.7"
10,000 RPM
CAT 40
24 ATC
Equipped With -
15 Bar (217 PSI) Coolant Thru The Center Of The Spindle, Visiport Inspection Thru The Center Of The Spindle
064081 2003 DEMO Deckel Maho DMC64V Linear Drive Vertical Machining Center, Siemens 810D Powerline Control with Electronic Handwheel Control (DEMO!)
X = 25.2" Y = 23.6" Z = 19.7"
12,000 RPM
SK 40
30 ATC
Equipped With -
Direct Measuring System, Linear Drive in X-Axis, Temperature compensation of the Z-Axis with temperature sensor, Visiport Inspection Window,
580 PSI Coolant thru the spindle, Chip conveyor, Machine electrics: 3 Phase, 400 Volt Input, 60 Cycle, Spray Gun
064063 Factory Overstock 2003 Deckel Maho DMC103V Vertical Machining Center, Fanuc 18i-MB 3-D CNC Control
Condition: Never Used or Installed, Factory Overstock
X = 39.4" Y = 23.6" Z = 23.6"
10,000 RPM
CAT 40
24 ATC
Fully Enclosed Cabin
063882 Factory Overstock 2003 Deckel Maho DMC103V Vertical Machining Center, Fanuc 18i-MB 3-D CNC Control with Electronic Handwheel (manual pulse generator) (Allows for manual movement or individual axes in various increments)
10,000 RPM
CAT 40
24 ATC
064074 2000 Deckel Maho DMC70V hi-dyn Gantry Style VMC, Heidenhain TNC 426/430 3-D CNC Control w/Electronic Handweel & Ethernet
Build Date: July 10, 2000
First Installed New: October 31, 2001
X = 27.6" Y = 21.7" Z = 19.7"
18,000 RPM
CAT 40
30 ATC
Equipped With -
Splash Guard with top closed, X/Y/Z Linear Direct Measuring System, Rotorclear Inspection Window, Chip conveyor,
Tool Breakage Monitoring Device with Tool Lenght Measuring, External Air Blast Cooling thru pipes selectable by M Function or SoftKey
064084 2002 Deckel Maho DMC60S, Siemens Sinumerik 840D Powerline control, (DEMO!)
064088 2003 Deckel Maho DMC60S 6-Sided Universal Bar Machining Center, Siemens Sinumerik 840D Powerline control, (DEMO!)
Feed Rate Longitudinal/Transverse/Vertical = 15,000 mm/min
Rapid Traverse/Transverse/Vertical = 50/50/50 m/min
Working Area -
Longitudinal = 760 mm
Cross = 460 mm
Vertical = 560 mm
HSK-A63
12,000 RPM Motor Spindle
call for more info!!!
LASERS
064056 Demo Model 2002 Deckel Maho DML 40SI 6-Axis Laser Machining Center
6-Axis Version with Optical Depth Measuring Sensor
Laser Type: Q-Switch-Yag
Laser Performance: W/100
Technology:
Machining Area Of The Laser: 2.4" x 2.4"
Automatic Tram for Larger Workpieces
Depth Measurement: Optical Depth Measuring Sensor Over The Whole Surface
Equipped With -
Laser Control Lasersoft 3D, Heidenhain MT 60 Measuring Probe, Larger Laser Safety Window 11.6" x 8.2", CCD Camera Alignment System, Dust Extractor with filter,
Water/Air Cooling Unit
Kind Regards
Joe
Joe Anselmo
Area Sales Manager
Fax (847) 781-0388
Cell (224) 595-2272
www.dmgamerica.com
May 2005
LATHES
Bar Capacity: 2.56"
Bar Capacity: 2.56"
Operating Range:
Sign Diameter: 5.7"
Working Area ---
Working Area ---
Bar Capacity: 2.56"
18,000 RPM
CAT 40
18,000 RPM
CAT 40
32 ATC
18,000 RPM
SK 40
60 ATC
Equipped With -
18,000 RPM
CAT 40
30 ATC
Equipped With -
5-M Functions (TNC)
18,000 RPM
SK 40
60 ATC
Equipped With -
10,000 RPM
CAT 40
24 ATC
Equipped With -
12,000 RPM
SK 40
30 ATC
Equipped With -
10,000 RPM
CAT 40
24 ATC
10,000 RPM
CAT 40
24 ATC
18,000 RPM
CAT 40
30 ATC
Equipped With -
Working Area -
Cross = 460 mm
Vertical = 560 mm
HSK-A63
LASERS
Technology:
Equipped With -
