We've got a little design task here. After looking at the options and the constraints involved with a module that installs in another machine, we're thinking about designing our own custom hydraulic cylinders--roughly 2.5" diameter, but with a short stroke, only about 1/4". The standard off-the-shelf Parker compact hydraulic cylinders won't integrate cleanly. Even though it's a pain, it looks like things will package best if we machine the bores right into some other components.
We've made plenty of custom pneumatic cylinders but never hydraulics. Searching online, I can't find much info for hydraulic cylinder design guidelines. If we're operating at 1000 psi, is there any magic involved with seal selection beyond the Parker o-ring/seal handbooks? It's going to see a lot of cycles, about 5 million per year, so longevity is a concern, too. It's ok if the customer has to spend 2 hours changing seals every million cycles, but the metal needs to last a lot longer. Can we do this in polished steel bores, or do we need to get everything hard-coated?
It'd be great to get some input/advice from someone who's been here before.
