CarbideBob
- Jan 14, 2007
- Flushing/Flint, Michigan
Weird that the OP asks for help here but seems to knowing it all already and does not care to listen.
Bob
Bob
I thought I had replied but my message seems to have disappeared, sorry.
I only measured the machine servo resolution, not any kind feature on the part. My application requires good angular direction of the surface normals which means I need a good local precision but don't require a great global precision. If the tool length expands of a few microns from the start of the machining and the end, it doesn't matter as it won't impact the local precision. Climate control is therefore not important.
If you will, I only care about the surface finish and not about the precision.
Bob
Thanks, making a test part could be interesting, but seeing that the spindle is 3.7 kW (5hp) makes me think this is a machine meant for rough work and steel machining. There will likely be a lot of vibration and big runout. A Nakanishi spindle has a power of 300W but is optimized for precision which I think is more adapted for what I'm looking for.
Optical,
Have you tried bolting your existing Roland to a 100-200kg lead plate?
PM
It sounds like you have a fairly unique application. You are relatively unconcerned about global accuracy, but want a really good surface finish. If the Roland is almost there, but the spindle is the problem, would the most economical option be to replace the Roland's spindle with a high-speed NSK unit. They have some that direct clamp onto 6mm tools that have a great runout. It eliminates the runout of the toolholder entirely; there isn't one.
I think it would also be worth looking at the Haas CM-1. It's a pretty small machine at a decent price that might do what you need. It would probably at least be worth having the distributor do a test piece for you.
Also out of your price (and size) range, but Fanuc also makes a robodrill with 0.1um programmable resolution and spindles in the 20-40krpm range. I've seen diamond milled optically reflective demo parts off this machine at expos, but of course I didn't measure them. You might contact a Fanuc representative to see whether they can sell you an entry level robodrill with an extra decimal place in the control.
We have a 1.5m swing Okuma VTL at my company with 0.1um minimum programmable increments (lol). And when you check with an indicator it even (sometimes) moves in these increments! But it's about 50x and 100x your respective price and weight budgets. Also the way the VTL does (and does not) follow commanded increments is illustrative of how these small increments can be very challenging: it has heavy axes running on box ways. On intermediate speed dynamic movements it can actually position in submicron increments, however it struggles with small motions due to stick slip; you can see servo overshoot and jerky motion due to trying to overcome static friction to move a 6000kg axis in tiny increments.
I assume the toolpath control the OP is referring to is planning toolpaths that are all one tool and the tool spirals or zigzags across the part so that each pass of the tool is close in time to its neighbors, that way thermal drift or axis scaling issues don't cause discontinuities. I would still expect to see big problems at axis reversal points if there are any mechanical issues (such as backlash or stiffness issues in ballscrews, classic example is reversal lines on interpolated circles). It's still not clear to me what the additional decimal place provides if the machine is an order of magnitude less repeatable than the current programmable resolution.
I'll try to rephrase my initial question: do you think that a machine built for small precision work like the Minitech GX (granite base, THK linear rails, precision ball screws, Nakanishi spindle) can get a surface finish close to mirror (on brass for example)?
And a side question: their GX model has a granite base, do you think it provides a benefit if you only take very light cuts?
That's why a Hermle is so expensive.
Marcus
Edmund Optics® utilizes a wide range of CNC machining equipment including ultrasonic machining and high speed cutting (HSC) technology from DMG MORI® for the machining of complex optical component geometries. CNC machines offer the highest amount of precision and flexibility when it comes to fabricating components beyond basic shapes. Our true 5-axis precision machine centers have the capability to machine lightweight structures and high aspect ratio components with specialty bevels, precision holes and inserts, and mounting interfaces. In addition to optical glass, we can machine a wide range of demanding materials including ceramics, corundum, tungsten carbide, and even composites. Some high-tech materials, such as Tungsten Carbide and composites, cannot be machined using conventional machining and can only be shaped using ultrasonic machining.
CNC Machining | Edmund Optics
Dimensional Accuracy Linear: 2-8µm
Parallelism: 2µm
Concentricity: 7µm
Notice
