Doesn't matter... 3.6 v (total) or 4.5 v is close enough. Many supposedly 3.6 volt NiCad batteries measure over 4.2 volts fully charged anyway.Are you sure that the battery voltage is 1,5 volt, these of my card was Ni-Cd with 1,2 Volt.
So will NiCads.... in fact in my experience NiCads leak worse... keep a watch on either one. Having said that, I recently bought a new battery holder and 3 new NiCad batteries to install there .... the charge circuit is so weak in this case I seriously doubt the alkalines would hurt anything...but "just in case" gonna put NiCads in anyway...They will leak sooner or later, and possibly wreck something.
RKlopp
I have theorized in the past that perhaps a few extra tenths of a volt might make the difference in an EPROM working or not if some components are 'weak' on the board, but that's just my speculation...yet to be proven really.
I never said the EPROMs were powered by the batteries...I just meant that whatever the batteries do power, an extra tenth of a volt might make just enough difference in the circuit for the approriate EPROM to be allowed to enter into the circuit so to speak. I also said this could be completely wrongUnless I have misunderstood what you are trying to say, the EPROMs should not be powered by the batteries as there is no reason to do so. The battery should only power the SRAM to persist transient data. By their very nature, EPROMs don't have transient data, of course, hence there is no need to power them when the machine is off. And when the machine is on, nothing should be powered by the battery packs.
In that case perhaps explain (or speculate) what exactly IS going on. What I mean by that... if my module battery pack is above say 3 volts, the machine boots up just fine. But if it's below 3 volts, it will seize on the SPS error and not boot up all the way. And from what I understand from techs that know, that is normal for the D11 control...that pack has to have a min voltage for the machine to boot up.Whatever the case, the fact still remains that if everything is working properly, the batteries are not powering anything when the control is on. At that point the main power supply is doing the powering of the SRAM and the battery goes into a charging mode. So the extra tenths won't make a difference there.
Deckel Dialog11 Problema de arranque.
Hola a todos;
Gracias a todos por sus aportes pero mi problema persiste. No estoy seguro de que el problema esté en la EPROM.
Mis dos máquinas Deckel, FP4A y FP4-60T Estuvieron desconectadas durante un año. Cuando los conecté e iba a encenderlos, estaban atascados en la "Autoprueba" en el error SPS. El LED verde del CNC en la tarjeta NVS se apaga mientras que el de la tarjeta I/O pasa a rojo después de unos segundos. El LED NOT READY de la tarjeta NPC está encendido.
Por recomendación del Centro de Servicio Deckel, quitó el acumulador de la tarjeta NRP y cambió estos de la tarjeta NVS. Luego, el FP4A funciona normalmente solo durante un mes y luego tenemos el mismo problema, el FP4-60T ya no funciona. Luego intenté usar la tarjeta NPC de una máquina en la otra, cambiando la EPROM que contiene el Soft, pero el problema persiste. Según el técnico de Deckel, el problema es una tarjeta NPC.
Estaré muy agradecido si alguien me puede ayudar a detectar la avería. Que no me parece lógico que ambas tarjetas NPC tengan el mismo problema mientras que antes ambas máquinas estaban en perfecto estado de funcionamiento.
Gracias.
Atentamente.
Bilel HASSAID.
Hola;
Tengo un problema en una tarjeta NCP (SPS) de mis máquinas usadas Deckel FP4A/Dialog11 y FP4-60T/Dialog11, la SPS EPROM estaba dañada. Entonces, ¿alguien puede decirme dónde puedo obtener el software para recrear nuevas EPROM?
Muchas gracias.
Atentamente
B. HASSAID.
Hola;
Muchas gracias.
Atentamente
B. HASSAID.
Interesado estoy en arreglarlo, el error que me dijo el técnico fue que podrian ser las pilas pero mi duda, es si hay cambiarle las pilas puede que se pierda alguna memoria de la máquinaPara decirlo con las palabras del infinitamente paciente y sabio Ross:
"Supongo que no estás interesado en tener una amplia reacción/discusión".
También parece una pregunta "el motor de mi automóvil está roto, ¿cómo lo arreglo?"
No todo en la tarjeta NPC está relacionado con SPS/PLC, pero esta tarjeta es la más costosa de reparación
No todo en la tarjeta NPC está relacionado con SPS/PLC, pero esta tarjeta es la más costosa de reparar.
Au weia
Notice
