The NGC definitely shows you the actual feed. And it is very fast. It's definitely faster than Mazak VTC, or Hyundai F500. I'd venture it's also probably faster than the Doosan. Is it more rigid, no.
how much money you wanna lose? because i can prove it to you.
hell, even the haas apps guys will admit that it doesnt display actual feed, only whats programmed plus/minus what you set your overrides to. i mean for fucks sake, program a contour with straight lines and some tight corners at 100 ipm, and look at the feed speed as its 'cutting'. it will display 100 ipm even in sharp 90* corners. if you really think ANY machine can do that without slowing down even a tiny bit, you're higher than a fucking kite.
