marccongdon
- May 19, 2021
I've been trying to get the draw tube out of this actuator and it won't budge, I've been using a pipe wrench with rubber pads or a chain wrench with a rag and a pry bar between two of those bolts to hold it back. I'm hesitant to use any heat on it because I know there's an O-ring right behind there though I suppose at this point I should rebuild the cylinder anyway. From what I can find some drawings show the actuator with a lock nut on the outer side, some with no lock nut at all. The Actuator is an LMC ZKP150/52-22 and it's out of a 2001 Haas SL-20. I also can't get the back ring off, I've taken out the two set screws and given that some heat but still nothing. Is there something I'm missing here?
