Searched and didn't find anything about this, if you know of a thread please point me in the right direction.
I'm building a lathe with a long, narrow granite surface plate as the bed. I am going to drill and epoxy inserts to hold linear rails for the ways. Anyone have experience drilling granite? I've seen some people use diamond core drills, and others use carbide tipped masonry type drills. My main concern is tool life, as I need something like 40 3/8" holes and a few 5/8". Also, any recommendations on the epoxy?
I was also wondering if anyone has had experience bonding steel plate directly to granite. I need to mount the z axis screw off the back side and was thinking of bonding drilled and tapped steel as the mount for the bearing blocks. I want to avoid drilling holes here as it will be close to the edge. Then there might be the odd limit switch mount or such that would be nice to epoxy onto the granite.
Any thoughts are appreciated.
