i'm having a problem with drills breaking on this job. 1/2-20 grade 5 bolts, 1 inch long that I am drilling a 5/16 hole through the length of. I'm running this job on a Haas VF2. I'm using cobalt 5/16 drills, 135 degree split point at 900 rpm, 5.5 ipm in an ER collet holder pecking every diameter. Using flood coolant at a higher concentration than I typically keep it at. The drill appears to be getting very hot towards the bottom of the hole before it breaks through, the overall length of the bolt including the head is around 1.375 and the drill starts making noise around 1 inch deep. Stopping the drill before it breaks and checking it out, the cutting edge is very worn. I am spotting these holes with a 120 degree spot drill. I do not have thru coolant capability unfortunately. I have 1000 of these bolts to drill so doing it on the bridgeport (to get a manual feel for how the drill is behaving) is not really an option. I'm currently getting 10-15 holes out of a drill. Any suggestions would be appreciated
