AllOutMachine&Fab
- Jul 19, 2022
Hi everyone, im having some issues getting my dynapath delta 20 control (late 80s to early 90s) to communicate with my computer. Machine is a tree journeyman 325 with the rs232 serial port. Ive configured a cable per dynapath to be compatible with hardware or software handshake, i believe the cable is correct because i can send program to the dnc software but it appears as garbage data? (@$@@) I have tried every possible setting that I can think of. The dnc softwares ive tried are DNC4U and easyDNC, Also im using a startech db9 to usb adapter to go to laptop running windows 10. Ive only tried sending from the cnc to the DNC Software because i haven't had any luck past there. Ive used all different baud rates, software and hardware handshake, i am stumped? Hoping its something silly that im overlooking and one of you wizzards out there have overcame the same problem? Using;
7 data bits
Even parity
1 stop bits
Echo off
X1/X0 on and off
Baud rates from 300-9600
Just cannot get anything to work for me? Any help would be greatly appreciated, i know its an old machine, but id love to get it figured out before i pull trigger on a VMC.
Thank you
7 data bits
Even parity
1 stop bits
Echo off
X1/X0 on and off
Thank you
