For now i adjusted the OEM pressure switch to 9bar (130psi) cut out. Will run it like this for a while to see if it really is failing or of it was just set too high... I'd rather buy an all in one solution that works well then to have lefoo going to magnetic contactor etc. Same idea, but in a nice OEM package, even if it costs like $100-$200 but is a drop in replacement that will just reliably work, would be preferred. 90 percent of this compressor use is for blasting, which sometimes i want to do at 90 psi with SiC, so pressure range of 100-150 psi is plenty for my contactor needs. 100 to 130 may even be good enough. The extra 20 psi from 130 to 150 won't save or kill me.
