I have a Baldor 3hp 3450rpm TEFC motor that was "seized" from being in the weather. I took it to a motor repair shop and the guy said sure, no problem. I called a few months later and he said he was real busy and had not been able to get to it. 6 months later I stopped and asked about and saw that it hadn't moved from the spot on his bench where I put it when I dropped it off. I asked him nicely to please fix it up figuring it would be no more than a 3 hour job or less for him. He called the next day to tell me that it was nor repairable and that the armature was rusted solid to the field and offered to throw it out for me. Well thanks for that but told him I would come and get it. He had taken off one end bell and yes it was a bit rusty in there but when I got it back to my shop, a light tap with a copper mallet moved the armature. A few more taps and it was out. There were some flakes of rust here and there but it all seems okay with the exception of one bearing which was a little crunchy and what I think is part of the starter switch which is what I have questions about. There is a phenolic disc with some stamped parts under it and a compression spring. When I used a screwdriver to poke the spring around it moves freely but none of the parts that the spring bears against will move so I wonder if something is rusted to the shaft. I have never attempted repairing something like this so it is all unfamiliar to me. Should I be able to move any of these parts? Thanks for any help with this.
