Joe in NH
- Jul 28, 2007
- Stratham, Cow Hampshire
It is going to take a whole lot of climate change before I have to worry about condensation. I have some sodium silicate and was planning on applying it first as a sealer/densifier, maybe a radon blocker. This first area is the test bed for what I do with the rest of the areas.
Were it mine I would not "seal" the concrete prior to paint. For the same reason that oil doesn't soak into the concrete, paint might be "challenged" in its adhesion - which relies heavily on a "porous" surface to anchor.
Paint should supply all the barrier you need against radon which is hazard in the "gas" (Daughter's house/well has radon in her water to 5x the recommended federal limit - this is not unusual here in rocky Cow Hampshire)
Ventilation is far more valuable in reducing radon.
Joe in NH
