johansen
- Aug 16, 2014
- silverdale wa
An ato transformer with a capacitor across one of the coils will couple the signal directly into the output, without attenuating the signal. Obviously, one capacitor, not two.
175' might not be festooning, rather it might be bus bars.
Can you run an IR link ? Put stationary unit at one end of rail, shooting along the rail.
pickup on bridge.
Do you need to just get to bridge, or all the way to the trolley ?
Might be a simple mirror on the bridge to turn the IR 90 degrees.
Just to the bridge - and the power is already on bus bars . . . with the favored solution using those same bus bars for Ethernet.
I found 2 each 50VA 480:120 transformers in our test inventory and am going to give them a shot on Monday.
Thanks for that.
Figured it was a dumb Q, just didn't know why...
At one point there was a standard for wireless communication intended for dorms and apartments and such. An IR transceiver was mounted on the ceiling, and and another was on an ethernet dongle that connected to the computer. It was led based and only required a line of sight, and no aiming at all.
I personally think this system would be more reliable, but maybe for the data rates a bunch of lost packets don't matter much.
IIRC more modulation frequencies are available than for wifi, but I'm not totally positive about that. Speed is certainly lower, but not awful. Transmitters and receivers are also very easy to physically shield from sources of interference with a small shroud.
EM spectrum is continuous. Absolute top of what we call "RF spectrum" is the bottom of the light band share. Radiated heat.
IR's transport layer is not slower. Latency and error-correction for S/N ratio ain't as easy.
Too many natural heat sources around, plus a ton of other man-made players.
We started down this path when we embedded 3 motion control enabled servo drives inside a 15 foot long 16 inch diameter spinning tube that was fed via a slip ring. The drives were mounted to a carriage that travels inside the tube from one end to the other. Having communications go through a single flex rated power cable inside the tube and a slip ring to go from stationary tethered point outside the tube dramatically saved cost and complexity. This worked well @ 230VAC using a pair of consumer grade units from NetGear.
Now we are looking to solve this problem with auto positioning cranes where adding flex rated Ethernet over 175 feet of bridge travel is more complex and more expensive than if we can get this system to work @ 480V.
Notice
