Euro-Mill Registry
Brand of Machine: Deckel
Series of machine: FP
Size of machine: 2
Style of machine: dual dial
Year of machine: 1967 ?
Serial number of machine: 2200-5325
Measuring standard: Metric
Taper: SK40 S20x2
Input voltage: 3 phase 380V
Cabinet style: Ext. cabinet, green
Color of machine: Original gray (repainted in green)
Condition of machine: undergoing a full rebuild
Major acc's: Large fixed table, Swivelling table, Acurite III ,Rotating table
Spiral milling table
Primary use: hobbiest, Prototyping and custom parts for my Ducati
City, Country: Marche, Italy, Europe
New addition to the corral. Joins the Deckels, etc:
Brand of machine: Aciera
Series of machine: F1
Size of machine: teeny tiny
Style of machine:
Year of machine: Early 1960s (??? S/N 32505 is 25 Nov 1968)
Serial number of machine: No. 21246
Measuring standard: Inch
Taper: Schaublin W20
Input voltage: 120 volt
Cabinet style: No cabinet.
Color of machine: Grey.
Condition of machine: Good.
Major acc's: "Simple" dividing attachment
Primary use: Hobbiest.
City, Country: Sunnyvale, CA, USA
Comments:
Other machines: Deckel FP2, Deckel FP3NC, Hurco CNC, Emco Maier EmcoTurn 120, Lorch LAS, Hardinge HLV-H E/M, Eguro 712, Monarch 10EE
Size of machine: 1
Style of machine: change gear feeds (two lever)
Year of machine: 1948
Serial number of machine: 27231
Measuring standard: Imperial
Taper: MT4
Input voltage: 3 phase 415V
Cabinet style: pre cabinet era
Color of machine: Original grey RAL 7005
Major acc's: Large fixed table, universal table, Walter rotary table,
vertical head, horizontal support, high speed head, slotting head, Wohlhaupter boring/facing head, dividing head with overarm, S20 collets, spares.
Primary use: hobbyist.
City, Country: Melbourne, Australia
Aciera F4
Series of machine: F4
Size of machine: 16 x 7.5 x 18 (400 x 190 x 450 mm) travels
Style of machine: universal
Year of machine: 70s-80s
Serial number of machine: 45087 (that's the number stamped at the top of the vertical column dovetail)
Measuring standard: inch
Taper: NMTB40
Input voltage: 220 single phase to two VFDs
Cabinet style: no cabinet
Color of machine: grey
Condition of machine: good
Major acc's: vertical head, horizontal overarm, 3-axis DRO
Primary use: hobbiest (engine models, parts for machinery restoration), prototyping (various inventions for my employer), lab mechanical test fixtures.
City, Country: SF Bay Area, California, USA
Comments: The machine is ex-Honeywell Aerospatiale, Quebec, Canada, via Procyon Machine. It had some bearing corrosion issues when it arrived, which I fixed. Canadian 575V motors were swapped out for new 240V motors. I had to modify the rear cover to fit the new spindle motor. The safety switch formerly on the side of the base was replaced by a Hoffman enclosure containing two VFDs. The machine is nice to run, though ergonomics are a bit strange to me. Nevertheless, the Deckel FP2NC is nicer to run. I also have an Aciera F2.
After a few months of loitering I thought I better pipe up and add my 13 to the list.
Bob.
Brand of machine: Schaublin
Series of machine: 13
Year of machine: 1962
Serial number of machine: Machne No. 537 BL No. 115401
Measuring standard: metric
Taper: ISO30
Input voltage: 240 single phase to 240 three phase via TECO VFD
Condition of machine: Great
Major acc's: Universal table, high speed head, sensitive drilling attachment for normal vertical head, simple dividing head with tailstock and support beam, OPL optical micrometers for X and Y axes.
City, Country: Perth, Western Australia
Comments: Formerly the property of the Aeronautical Research Laboratories
which formed part of the Weapons Research Establishment located at Salisbury in South Australia.
this machine followed me home from Prototypers
last week;
Brand of machine Deckel,
Series of machine: FP4 NC
Size of machine: 4
Year of machine: 86?
Control model for NC Dialog 4
Input voltage:380?
Color of machine: green
Condition of machine: looks ok to early to be sure
Primary use: fun and work
City, Country:powell river ,canada
Maho MH600
Brand of machine: Maho
Model: MH600
Year of machine: Late 1962
Serial number of machine: 11660
Taper: No. 40. Fitted with the Deckel style drawbar (tool holder has a male buttress thread)
Style of machine: 2 dial machine. The feed dial controls a variable speed device that is driven by a 2 speed motor.
Input voltage: 600, 3Ø
Cabinet style: Electrics contained in a small cabinet on the LH side of the machine
Major acc's: Universal table (swivel/incline/tilt), vertical head, slotting head, over arm, rotary table, complete dividing head, punch milling attachment, accessory cabinet. Also came with a Burnerd 2 speed vise and hefty swivel/tilt vise.
City, Country: Red Deer, Alberta, Canada
Comments: This was formerly a government institution machine. I purchased this machine at a public auction. I felt fortunate to track down the manuals, product brochure and test cards from the previous user (the machine had been surplused nearly 4 years prior but had taken a while to get to the auction – the previous owners had not cleaned out that part of the file cabinet!).
Year of machine: 50s?
Serial number of machine: k.A.
Taper: vert:30/hor:40
Input voltage: ~3/400v@50Hz
Color of machine: original
Major acc's: vertical head, horizontal overarm, 2x dividing engines + tailstock, misc tooling.
Primary use: custom tooling and maintenance for woodworking machines, prototyping.
City, Country: Roggwil, Switzerland
Comments: I finally have my very own!
Picasa Web Albums - John Candlish - aciera-f4
Thiel duplex 58
Brand of machine. Thiel
Series of machine: Duplex 58
Style of machine: Vertical and horizontal
Year of machine: 1932+
Serial number of machine: not yet found
Taper: Thiels own
Input voltage: converted to 240 volt but going back to 3 phase
Color of machine: Was light green going to be blue
Condition of machine: fair but in sate of reconditioning
Major acc's: Thiel dividing head, swivel and tilt table
Primary use: one off parts for motorsport
City, Country: Chesterfield England
Comments: Previously tool room mill at Markham works Chesterfield.
Abene VHF 3
Brand of machine Abene
Series of machine: VHF-3
Size of machine: (3
Style of machine: manual
Year of machine: 1970
Serial number of machine: (optional)
Measuring standard: (imperial)
Taper: (NMTB40)
Control model for NC's: N/A
Input voltage: (220, or 440 currently running on 220.)
Cabinet style: (no cabinet)
Color of machine: (grey)
Condition of machine: (good)
Major acc's: (trav-a-dials on X,Y, various after market accessories)
Primary use: (hobbiest)
Comments: 6 hp spindle, 2 hp ways, flat belt for ways, tripple belt for spindle
Deckel FP4M
Size of machine: 4
Style of machine: 3 Dial two motor
Year of machine: 1985
Serial number of machine: 2109
Measuring standard: (imperial-metric)
Taper:ISO40
Control model for NC's: none
Input voltage: 220 Transformer 380 3ph
Cabinet style: Small side ext cabinet
Condition of machine:great
Major acc's: 3 Axis DRO VRZ773
Primary use: prototyping
City, Country: Maryland US
Comments:
Size of machine: 4
I'm pretty sure Deckel didn't make an FP4 in 1985. So either you got the year or the model wrong.
Adding an Abene to the list
Series of machine: VHF-2B
Size of machine: 2 Hp spindle
Style of machine:
Year of machine: May, 1953
Serial number of machine: 537
Measuring standard: English
Taper: NMTB40
Input voltage:220/60
Cabinet style:
Condition of machine: good-great
Major acc's: 1" arbor, rotary table, dividing head
Primary use: General machining
City, Country: Stockholm, Sweden
Comments:
Tom
Series of machine: FP-4NC
Year of machine: 1986
Control model for NC's: Siemens 3M
Input voltage: 380
Primary use: prototyping - production
City, Country Lancaster PA
2nd owner
Series of machine: FP-7NC
Taper: 50
Control model for NC's: Dialog 4
Input voltage: 380
Major acc's: Universal table w/C axis
City, Country: (Deckelville, Deckelland)
Comments: 3rd owner - 1st owner was the applied Physics lab at Johns Hopkins Univ.
Old MAHO MH600
Hello @ All,
one more of the nice old MAHO MH600, first generation.
Brand of machine: MAHO
Series of machine: MH
Size of machine: 600
Style of machine: two dial
Year of machine: maybe '60
Serial number of machine: xxxxx
Taper: MT4
Control model for NC's: no NC's, pure manual
Input voltage: 3ph. 380V
Condition of machine: painting beat, mechanically fair
City, Country: Heidelberg, Germany
Comments: It's one of the old rare MH 600, maybe first generation of the MH600
Andreas
Hello!
Just bought this one:
Year of machine: does somebody know?
Taper: MT4
Color of machine: white and blue
Condition of machine: painting beat, mechanically perfect
Primary use: knifemaking
City, Country: S J Rio Preto, Brazil
Comments: Can someone say to me when aprox. this machine was made?
I just unloaded this from the delivery truck an hour or so ago and peeled off the shrink-wrap. Man, I just love the German mechanical aesthetic!
Brand of machine: Deckel FP2LB
Style of machine: Seriously cool
Year of machine: Don't know yet
Serial number of machine: 0513
Taper: ISA 40
Input voltage: 220/3ph, ~3HP
Cabinet style: Electrical box? External
Color of machine: grey/green original, paint worn on top of ram and heavy checking on the base, but otherwise very nice - wouldn't consider refinishing at this point.
Condition of machine: nice original condition, .020 or less backlash, table shows a couple of operator errors, but most of the original scraping is present.
Major acc's: Came with a variety of tool holders, arbors, misc.
Primary use: Hobby, custom gunsmithing, prototyping some ideas which may have commercial applications.
Comments: A little overwhelmed by this machine and could very much use any documentation available for operation, maintenance, parts, etc. I like the big, heavy, stationary table just 'cause, but also for mounting a rotary cross slide table, big B&S dividing head, etc. Pictures once I move some stuff and get it up and running in it's place of honor in front of a big window.
Schaublin #13 Mill
Thought I would add a little gray to the green here
Series of machine: #13
Year of machine: 1950's ?
Serial number of machine: Machine # 1053 BL # 144984
Taper: No. 30
Input voltage: 3 Phase 220
Cabinet style: None / Cast Base
Color of machine: grey - appears to be original paint
Major acc's: Horizontal arbors & support
City, Country: Wisconsin, USA
Comments: Appears to have come out of Maryland, purchased in Wisconsin
Would like to find the vintage optional accessories for this mill.
Bernard
Size of machine: 3NC
Year of machine: 1984
Serial number of machine: 2803-2276
Measuring standard: metric and inch
Taper: SK40-DIN 2080
Input voltage: 380V
Cabinet style: ext cabinet
Color of machine: greenish gray, propably repainted
Condition of machine: great
Primary use: prototyping-production
Country: Greece
Series of machine: KF
Size of machine: 12
Year of machine: 1969
Serial number of machine:-
Input voltage: 380V
Cabinet style: int. cabinet
Color of machine: dark green
Condition of machine: very good
Primary use: mold/prototyping
And two east! german milling machines that can't tell if they really belong in this group....
Brand of machine: WMW-RUHLA
Series of machine: FUW
Size of machine: 315/III
Year of machine: 1981
Taper: SK40
Input voltage: 380V
Cabinet style: (ext cabinet originally), internal builted
Color of machine: Beige
Brand of machine: WMW-HECKERT
Size of machine: 400 2/II
Year of machine: 1980
Taper: SK40
Input voltage: 380V
Color of machine: White
Primary use:production
