Excello XLO 602 Vertical Milling Machine Ram Turret
Dan323
Mar 20, 2014
Syracuse NY
I recently moved into a smaller shop at my house and need to make some room. I bought this mill to be a second machine and just can't justify the floorspace for 2 mills.
Asking $2400 or best offer.
Located in Cicero, NY. Forklift loading available.
XLO 602 Vertical Milling Maching - Serial # 6020963
Full Album of Pictures
Includes 6" Swivel Machining Vise and Riser Block (As pictured). The vise hasn't been used since it was torn down and painted.
Canadian built similar to a Bridgeport but regarded as much stouter. This machine weighs somewhere around 3100 lbs.
Unit is stored inside under power and can be tested.
Variable speed and two-speed transfer case both work as expected. Gearbox is currently lubricated with Mobil SHC 630/ISO 220 per spec. Table is lubricated with Vactra II. Spindle with Velocite #10.
-42" Table
-3-phase 208V 1.5HP Motor. R8 Spindle
-85-4000 RPM Infinitely Variable Spindle
-Power downfeed
-Spindle Brake
http://www.lathes.co.uk/excello/
http://manuals.chudov.com/Excello-602-Mill-Manual.pdf
Local delivery (150 miles of Cicero NY) is available for an additional cost if you have a way to unload it from a flatbed trailer.
Freight shipping may be available. Send a message for quote.
