Fadal Probe programming help
Austinbowden
Aug 4, 2021
CLIFTON, NEW JERSEY
I just can’t find people who actually understand the subtle details that matter in probing on old fadal
Attached is a program and I only want to know why if I put #clear on my firs line- it will wipe the v1 through v99 AFTER my M2
It’s almost like it reads the program before I even push start
If I feed hold and look at variable table before the M2 the variables are all there
Next question
Sometimes the machine will rapid over to the XYZ location or get in a position to begin probing and it will basically skip the G31 and just continue on (rapid up and over to next location without ever taking a reading
-It’s so intermittent that doesn’t make sense and it’ll skip over a bore for no apparent reason
And my last question is this
— In the book I see G31 with “P1” plain-and no “R” in the line
And other places (as examples) I see the same G31 code with “R1=P1 etc
I am not able to wrap my head around the difference but it’s not going to surprise me if there is a big difference
There’s just such little literature out there
N1 O7778 (PROBE DIAMETER)
N2 ( TOOL 12 IS PROBE )
N3 #WAIT
N4 G90
N5 G0 E40
N6 #V24=FX40
N7 #V25=FY20
N8 #FX41=V24
N9 #FY41=V25
N10 #WAIT
N11 M0
N12 G0 G90 Z3.
N13 G0 G90 E40 X0 Y0 G90
N15 G90 G0 H99 Z2.
N17 G90 G1
N19 G31 Z-0.2 F50. P1
N20 #WAIT
N21 #V5=AZ
N22 #V4=AY
N23 #V3=AX
N24 #WAIT
N25 G90
N26 G1
N27 #WAIT
N28 G31 X-0.5 F50. P1
N29 #WAIT
N30 #V9 =P X1
N31 #WAIT
N32 G1 G91 X0.05
N33 #WAIT
N34 G90
N35 G1
N36 #WAIT
N37 G31 X-0.5 F2. P1
N38 #WAIT
N39 #V10 =P X1
N40 #WAIT
N41 G91
N42 #WAIT
N43 G1 G31 X0.1 F50.
N44 #WAIT
N45 G90
N46 #WAIT
N47 G1 G31 X0 F50.
N48 #WAIT
N49 G1 G31 X0.5 F50. P1
N50 #WAIT
N51 #V11 =P X1
N52 #WAIT
N53 G91
N54 #WAIT
N55 G1 G91 X-0.05
N56 G90
N57 #WAIT
N58 G1 G31 X0.5 F2. P1
N59 #WAIT
N60 #V12 =P X1
N61 #WAIT
N62 G91
N63 #WAIT
N64 G1 G31 X-0.1
N65 #WAIT
N66 G90
N67 G1
N68 #WAIT
N69 G1 G91
N70 #WAIT
N71 G31.1 X-0.05 F50.
N72 #WAIT
N73 G90
N74 G1
N75 G31 X0 F50.
N76 #WAIT
N77 #V15=V12+ V10
N78 #V13=V15 /2
N79 #V14=V24+ V13
N80 #FX42=V14
N81 #V20=V10- V12
N82 #V21=D99
N83 #V22=V20- V21
N84 #WAIT
N85 G90 G1
N86 #WAIT
N87 G31 Z0 F50.
N88 #WAIT
N89 G0 Z1.
N90 G0 G91 Z2.
N91 M2
I think my document software added some spaces BTW but in the machine it’s good
I also wonder if the
#wait Command is modal like it is in the fanuc - turn read ahead off
Try with a G4 P[Time in milliseconds] Fadal doesnt use #wait I believe. Info from the manual
Whenever a pause in the program is required, use the G4 code.
A pause may be used to allow the spindle and coolant to fully turn on after
using the M3 and M7 or M8 codes. This often happens with a tall part or fixture,
where the tool gets to the top surface before the spindle is up to speed.
EXAMPLE: G90 G0 S10000 M3 E1 X-.45 Y-.2
H1 Z-.3 M8
G4 P1000 (This one second dwell allows the spindle to come up to speed).
X3. G1 F80.
• A P word represents time. The time is given in milliseconds.
• P1 = 1/1000 second (or one millisecond)
• P500 = 500 milliseconds or 1/2 second
• P60000 = 1 minute
The G4 would also be used in a situation where the tool needs to dwell to allow
for spindle rotation, such as a spot face or counter bore situation. A general
rule to follow is to dwell for at least three revolutions. To calculate elapsed time
April 2003 Section 3: G Codes 49
Fadal User Manual
during three revolutions divide 180,000 by the RPM used. The 180,000
represents time in milliseconds for three minutes.
EXAMPLE: For 5000 RPM:180,000 / 5000 = 36
G1 F10. Z-.25
G4 P36 (Dwell for 36 milliseconds; 3 revolutions at 5000 RPM).
Z0 G0
G4 as an In-position
Check
The use of a G4 without the P word will perform an in-position check. This
would be non-modal and would only affect the line in which it existed. See also
G9.
X1.0 G4 (An in-position check is forced here).
X2.0
X3.0
G4 as a Program
Stop
The use of a G4 with P66000 forces an endless dwell or a program stop,
placing the machine in the waiting state. When in the WAITING state the spindle
and coolant will remain on, as opposed to M0 and M1 which turn them off. To
continue program execution press the Start or Auto button
