Now that I have the RS-232 port functional on a Fagor 800T based controller, the next step is to control it from PC.
The standard WinDNC software is installed, and the "DNC" marker shows up on the top far left section of the controller's screen as required. Parameters P605(5,6,7,8), P606(8) and P623(2) were set to one (counting bits from right to left starting from one), as requested by the manual. Strangely, the appendix F of the manual simultaneously states that P623 is not currently in use.
Apparently only the program 99996 can be ran from PC and stored as G-code on the controller.
A very simple program which should be in the correct format has been prepared in Notepad++ *). However, when attempting to run the program from WinDNC's infinite mode there are two errors.
1. The program 99996 is already stored on the machine. Fine, it is possible to delete in WinDNC, however very annoyingly the controller rewrites a default program within seconds! Is this behaviour possible to disable?
2. Internal error.
How may I resolve the errors?
*) In the 800T manual it is stated that the program should start with a NULL character. If this is attempted the program complains that the name is incorrect. Therefore the null is omitted, however the somewhat unusual <LF> and <EOT> characters at the end of lines and the program are included for now. The program loaded up fine by transmitting it from WinDNC, even with comments designated by ().
2. Internal error.
