Hi,
I work at a custom ski shop and we are trying to create a program that will taper a ski core. However whenever we try to run the G-code that was created through Fusion 360 we get a Z-axis soft limit error. I cannot figure out what the issue is but I have attached the Fusion 360 part file as well as the G-code.
I'm hoping someone can help us with this because if we can't taper the ski cores on the CNC machine then we have to use the drum sander which eats up valuable time.
Best,
CRSP Custom Skis
G-CODE:
%111111,MX--,
; USE CORE CUTTER 157 SPLITBOARD CORE 7MM THICK
; MACHINE
; VENDOR AUTODESK
; DESCRIPTION GENERIC 3-AXIS
; T1 D=0.5 CR=0 - ZMIN=0.0787 - FLAT END MILL
G90 G94 G17
G70
G53 G0 Z0
; PARALLEL2
T1
M101
; 12 BIG BOY
S12229 M3
G54
G0 X15.9988 Y77.4721
G43 Z1.14 D1
G0 Z0.1587
G1 Z0.1287 F550
G19 G2 Y77.422 Z0.0787 J-0.05 K0
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5084 Z0.4998
Y5.5459 Z0.0787
Y3.8
G2 Y3.789 Z0.0813 J0 K0.025
G3 Y3.778 Z0.0838 J-0.011 K-0.0224
G17 G2 X15.9238 Y3.703 I-0.075 J0
G1 X15.8238
G2 X15.7488 Y3.778 I0 J0.075
G19 G2 Y3.789 Z0.0813 J0 K-0.025
G3 Y3.8 Z0.0787 J0.011 K0.0224
G1 Y5.5459
Y30.5084 Z0.4998
Y50.7013 Z0.5
Y75.6654 Z0.0789
Y77.422 Z0.0787
G3 Y77.4331 Z0.0813 J0 K0.025
G2 Y77.4441 Z0.0838 J0.011 K-0.0224
G17 G3 X15.6738 Y77.5191 I-0.075 J0
G1 X15.5738
G3 X15.4988 Y77.4441 I0 J-0.075
G19 G3 Y77.4331 Z0.0813 J0 K-0.025
G2 Y77.422 Z0.0787 J-0.011 K0.0224
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X15.4238 Y3.703 I-0.075 J0
G1 X15.3239
G2 X15.2489 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X15.1739 Y77.5191 I-0.075 J0
G1 X15.0739
G3 X14.9989 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X14.9239 Y3.703 I-0.075 J0
G1 X14.824
G2 X14.749 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X14.674 Y77.5191 I-0.075 J0
G1 X14.574
G3 X14.499 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X14.424 Y3.703 I-0.075 J0
G1 X14.3241
G2 X14.2491 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X14.1741 Y77.5191 I-0.075 J0
G1 X14.0741
G3 X13.9991 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X13.9241 Y3.703 I-0.075 J0
G1 X13.8242
G2 X13.7492 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X13.6742 Y77.5191 I-0.075 J0
G1 X13.5742
G3 X13.4992 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X13.4242 Y3.703 I-0.075 J0
G1 X13.3243
G2 X13.2493 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X13.1743 Y77.5191 I-0.075 J0
G1 X13.0743
G3 X12.9993 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X12.9243 Y3.703 I-0.075 J0
G1 X12.8244
G2 X12.7494 Y3.778 I0 J0.075
G1 Y5.5475
Y30.513 Z0.4999
Y50.7013 Z0.5
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X12.6744 Y77.5191 I-0.075 J0
G1 X12.5744
G3 X12.4994 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.513 Z0.4999
Y5.5475 Z0.0787
Y3.8
G17 G2 X12.4244 Y3.703 I-0.075 J0
G1 X12.3245
G2 X12.2495 Y3.778 I0 J0.075
G1 Y5.5475
Y30.513 Z0.4999
Y50.7013 Z0.5
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X12.1745 Y77.5191 I-0.075 J0
G1 X12.0745
G3 X11.9995 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.513 Z0.4999
Y5.5475 Z0.0787
Y3.8
G17 G2 X11.9245 Y3.703 I-0.075 J0
G1 X11.8246
G2 X11.7496 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X11.6746 Y77.5191 I-0.075 J0
G1 X11.5746
G3 X11.4996 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X11.4246 Y3.703 I-0.075 J0
G1 X11.3247
G2 X11.2497 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X11.1747 Y77.5191 I-0.075 J0
G1 X11.0747
G3 X10.9997 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X10.9247 Y3.703 I-0.075 J0
G1 X10.8248
G2 X10.7498 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X10.6748 Y77.5191 I-0.075 J0
G1 X10.5748
G3 X10.4998 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X10.4248 Y3.703 I-0.075 J0
G1 X10.3249
G2 X10.2499 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X10.1749 Y77.5191 I-0.075 J0
G1 X10.0749
G3 X9.9999 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X9.9249 Y3.703 I-0.075 J0
G1 X9.825
G2 X9.75 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X9.675 Y77.5191 I-0.075 J0
G1 X9.575
G3 X9.5 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X9.425 Y3.703 I-0.075 J0
G1 X9.325
G2 X9.25 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X9.175 Y77.5191 I-0.075 J0
G1 X9.0751
G3 X9.0001 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X8.9251 Y3.703 I-0.075 J0
G1 X8.8251
G2 X8.7501 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X8.6751 Y77.5191 I-0.075 J0
G1 X8.5752
G3 X8.5002 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X8.4252 Y3.703 I-0.075 J0
G1 X8.3252
G2 X8.2502 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X8.1752 Y77.5191 I-0.075 J0
G1 X8.0753
G3 X8.0003 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X7.9253 Y3.703 I-0.075 J0
G1 X7.8253
G2 X7.7503 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X7.6753 Y77.5191 I-0.075 J0
G1 X7.5754
G3 X7.5004 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X7.4254 Y3.703 I-0.075 J0
G1 X7.3254
G2 X7.2504 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X7.1754 Y77.5191 I-0.075 J0
G1 X7.0755
G3 X7.0005 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5475 Z0.0787
Y3.8
G17 G2 X6.9255 Y3.703 I-0.075 J0
G1 X6.8255
G2 X6.7505 Y3.778 I0 J0.075
G1 Y5.5475
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X6.6755 Y77.5191 I-0.075 J0
G1 X6.5756
G3 X6.5006 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5475 Z0.0787
Y3.8
G17 G2 X6.4256 Y3.703 I-0.075 J0
G1 X6.3256
G2 X6.2506 Y3.778 I0 J0.075
G1 Y5.5475
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X6.1756 Y77.5191 I-0.075 J0
G1 X6.0757
G3 X6.0007 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X5.9257 Y3.703 I-0.075 J0
G1 X5.8257
G2 X5.7507 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X5.6757 Y77.5191 I-0.075 J0
G1 X5.5758
G3 X5.5008 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X5.4258 Y3.703 I-0.075 J0
G1 X5.3258
G2 X5.2508 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X5.1758 Y77.5191 I-0.075 J0
G1 X5.0759
G3 X5.0009 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X4.9259 Y3.703 I-0.075 J0
G1 X4.8259
G2 X4.7509 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X4.6759 Y77.5191 I-0.075 J0
G1 X4.576
G3 X4.501 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X4.426 Y3.703 I-0.075 J0
G1 X4.326
G2 X4.251 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X4.176 Y77.5191 I-0.075 J0
G1 X4.0761
G3 X4.0011 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X3.9261 Y3.703 I-0.075 J0
G1 X3.8261
G2 X3.7511 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X3.6761 Y77.5191 I-0.075 J0
G1 X3.5762
G3 X3.5012 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G17 G2 X3.4262 Y3.703 I-0.075 J0
G1 X3.3262
G2 X3.2512 Y3.778 I0 J0.075
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G17 G3 X3.1762 Y77.5191 I-0.075 J0
G1 X3.0762
G3 X3.0013 Y77.4441 I0 J-0.075
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G2 Y3.75 Z0.1287 J0 K0.05
G0 Z1.14
G53 Z0
G53 X0 Y0
M30
LINK TO FUSION 360 MODEL:
Fusion
Best,
CRSP Custom Skis
G-CODE:
%111111,MX--,
; MACHINE
; VENDOR AUTODESK
G90 G94 G17
G70
G53 G0 Z0
; PARALLEL2
T1
M101
; 12 BIG BOY
S12229 M3
G54
G43 Z1.14 D1
G0 Z0.1587
G1 Z0.1287 F550
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5084 Z0.4998
Y5.5459 Z0.0787
Y3.8
G1 X15.8238
G1 Y5.5459
Y30.5084 Z0.4998
Y50.7013 Z0.5
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X15.5738
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X15.3239
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X15.0739
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X14.824
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X14.574
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X14.3241
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X14.0741
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X13.8242
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X13.5742
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X13.3243
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X13.0743
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X12.8244
G1 Y5.5475
Y30.513 Z0.4999
Y50.7013 Z0.5
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X12.5744
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.513 Z0.4999
Y5.5475 Z0.0787
Y3.8
G1 X12.3245
G1 Y5.5475
Y30.513 Z0.4999
Y50.7013 Z0.5
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X12.0745
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.513 Z0.4999
Y5.5475 Z0.0787
Y3.8
G1 X11.8246
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X11.5746
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X11.3247
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X11.0747
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X10.8248
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X10.5748
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X10.3249
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X10.0749
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X9.825
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X9.575
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X9.325
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X9.0751
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X8.8251
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X8.5752
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X8.3252
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X8.0753
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X7.8253
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X7.5754
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X7.3254
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X7.0755
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5475 Z0.0787
Y3.8
G1 X6.8255
G1 Y5.5475
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X6.5756
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5475 Z0.0787
Y3.8
G1 X6.3256
G1 Y5.5475
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X6.0757
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X5.8257
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X5.5758
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X5.3258
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X5.0759
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X4.8259
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X4.576
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X4.326
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X4.0761
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X3.8261
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X3.5762
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G1 X3.3262
G1 Y5.5459
Y30.5185 Z0.5
Y50.7013
Y75.6654 Z0.0789
Y77.422 Z0.0787
G1 X3.0762
G1 Y75.6654 Z0.0789
Y50.7013 Z0.5
Y30.5185
Y5.5459 Z0.0787
Y3.8
G0 Z1.14
G53 Z0
G53 X0 Y0
M30
Fusion
