We've got some equipment that gets attached to a larger machine intermittently, which it's attached, they SHOULD hook up a cable, bug it's possible that they won't. I want on indicator on the removable part that shows if the cable hasn't been hooked up correctly. That is, it needs to indicate red when there isn't power. Possible options might be:
1) A red indicator held out by a spring, when the cable is connected, an electromagnet pulls it in.
2) Electrochromic glass covering a red panel. The glass is clear when there's no power, so the red is visible.
I'd like something off the shelf, but haven't seen anything. Does anyone know of a product that would work?
