Fanuc O-M will not send or receive programs from new computer?
Here are the settings on the Fanuc OM that are working for me. Can't hurt to double check those.
Remove everything here except the % and try again. Is the Machine throwing an alarm? or just sitting there?
So i tried doing as you advised removing the characters before the %, also removed most of the program accept one line and ended with M30 and % on final line. I tried again and still nothing LSK would just blink. tried setting the input command first then send and reverse send then input thinking it may want a certain order of command. No alarms. Which sometimes makes it harder. More clicking around and on Predator, DNC Properties, below the flow section i had the 3 boxes checked for (wait for cnc,RTS,DTR) i unchecked those boxes and that did the trick! It will now send with either start sting the one with characters or the %. Thank you for your input, ideas, and time.
  • Like
Reactions: VTM
Great! Glad you got It sorted
