With a lathe:
I'm taking about 0.0015" off the inside wall of an existing 0.260" hole in brass, depth is about 0.25", hole is open ended.
I started with a Micro 100 boring bar from Grainger as shown in the picture. I'm going in slow with lube and doing a spring pass on the way back out, the only thing I'd like now is a smoother finish. Not a NASA part, I don't have the ability to quantify the surface finish, just be nice to see more shine, less matte.
I've looked at other boring bars which appear as if they may be a tad more blunt, but nothing in the specs says they are designed specifically for finish cuts.
Also looked at the roller burnishers online but I have no experience with them.
Emery cloth for an outside I can imagine, not sure how I'd make it work on the inside.
Figured I'd ask the experts here for their suggestions.
Thank you.
Thank you.
