Shamban originally made Turcite and that's what I used, but when their patents ran out others made it. Saint Gobain made Rulon. Then Shamban went bankrupt and it was a pain to find Turcite I started to buy Rulon and still buy it from Tstar.com You should put in aa couple of Starrett 1/2" x say .010" hick shim stock under the worn hold downs and sweep or tram again. That would show you the front flats are OK and it is only the rear hold-down that bad.
Picking up on the head in front of the spindle, I had an indicator at the top and it moved 0.007-0.008" with light to heavy pressure, repeated it at the bottom and the indicator didnt pull away from the vertical column any when measured from the back side strap to see where the movement came from.
The first trip to Taiwan I was touring one of the factories and saw the M (Mehanite) and asked if they were using that patented iron mix? and they said the machines they copied had an M so they made patterns with the M, so I suspect your machine is grey iron.
from the slight grooving it does look like grey iron.
On your 2nd picture it sure looks like the side is pitted and scored too a little? Or is that just crud?
the side appears to have chips embedded into it, guessing from the lack of way wipers on the top.
I see the back is bad. If it is just the back. You may want to make up some sort of file holder and use a rough cut file and use it to file the back side. Use a vacuum to suck up the chips or dust instead of scraping back there. I would mill the hold-down flat and then glue on some Rulon 142. Member BMikelson has a lot of Turcite he can sell you as he bought a bunch of scraping tools and supplies from a rebuilder who retired. Ben sold some to a guy who needed some in another thread.
I have seen that thread and was wondering about messaging him, although being in Canada sucks for shipping. Was already emailing local companies that can supply this hopefully. I will email him also, as having a scraping tool isnt a bad thing if he had some of those also.
I had thought of possibly making something to go around the vertical column box way on the front, and have it guide to maybe have a die grinder horizontally to slide up and down the front good side and rough in the rear to be parallel to the front. Will have to figure it all out once i get in there. Then just make everything to fit.
For thickness, what would you recommend to do if I need to take off 10 thou let's say to clean it up, get 32 then machine or grind it down after install or before? or will I need to cut it down to 32 thou and put a full thickness piece in there?
I know I will have to fix the left side also before it gets bad, as that side has about 0.005" wear/freeplay on the top hold down also but the way looks pristine over there currently. will do that while im in there.
