Hey Guys,
I'm trying to standardize the way I callout my dowel holes. I typically use oversized dowels from McMaster-Carr with m6 fits.
I typically use H7 fits because it is common and seems to give a good locational fit or sometimes a light mallet tap. But I have also used F8 and G7 for more clearance and K7 for a press fit.
I typically call them out like so...
5.012
5.000 H7 X 7.0mm DEEP
My questions are 1) Are there certain fits that you would prefer/not prefer because you typically stock the reamers or does it not make any difference to you?
2) Is there a way that you like to see dowel holes called out? I have also seen callouts like (5mm DIA X 7.0mm DEEP, REAM TO CLEARANCE FIT FOR 5m6 DOWEL).
I prefer the first way because I assume it is less work for the machinist and a bit more defined.
5.012
