Good evening Practical machinists,
I am looking for a good solvent to keep 80 grit sandpaper from getting clogged with aluminum deposits from cast aluminum. My remanufacturing process requires flat sanding valve body castings on a slab of granite with 80 grit sand paper (affixed to the granite with clamps). I have fabricated a fixture to contain the granite slab and contain a solvent of some sort. There is a sump, filter and pump to keep a stream of solvent circulating over the sandpaper to "carry away" the deposits.
What would be recommended as a "healthy" low volatility solvent to keep in the open bath?
I emphasize wearing respirators whenever in these scenarios, but my advice only goes so far. Even though the PPE is provided, it is not always used by my technicians.
I was thinking mineral oil and used parts solvent, but I am open to any recommendations. We are using a metal gerotor style pump and ~5 micron hydraulic filter.
Thanks!
John
Thanks!
John
