M.B. Naegle
- Feb 7, 2011
- Conroe, TX USA
So I was at the point of "no more projects".... "oh look at that one!" This lathe was close and cheap enough to entice me, and does fill a couple gaps in the line-shaft shop's capabilities.
I picked it up yesterday afternoon and still figuring out what I got. Approximately 14" swing and 30" between centers (need to take the tape measure to it on Monday). It didn't come with any alternative chucks, cutting bits, steady or follow rest, but has a decent 4 jaw, turret style tool post, tailstock, and most all the important bits for an interesting taper attachment design. I think the cam arrangement on the end is for setting the taper. The back side taper attachment ways remind me of the old pratt and whitney lathes. There's no compound rest, but from what I've read these lathes were known to be heavy cutters rigid enough for carbide (when it first came out), though still with slow spindle speeds.
This lathe seems to be a later model with a lot of improvements for the company so I think it's a 1910's design. It actually shares a lot in common with my Whitcomb Blaisdell of the same period. The leadscrew on/off function and no threading dial are some of the commonalities, as well as having split plain spindle bearings. The under-bed chip pan is a handy shop improvement that seems well executed and will likely stay. The single tumbler QC gearbox is nearly exactly the same as my Heavy 10 South Bend.
It came with a Western Mfg. Overhead motor and gearbox arrangement. Though I want to go back to the line shaft flat belt design, the gearbox may yet get put to use. The upper cone will need to be replaced, but on the bright side the lower cone is mostly intact, just having a V pulley welded over the top of one step. They actually used an old Coca-Cola sign for part of a belt guard, but not sure how salvageable it is. It's funny how cyclical value is, with things start with intended purpose, become garbage, then have value again. The 25 cent price on the bottle of coke at least puts a date on the conversion.
The ways have some ridges, but honestly don't seem that bad. The rest of the lathe seems intact with nothing broken (so far). There is rust, as always, but still lots of oil between pieces. I think a full tear-down, clean up, and paint and polish is warranted, but will have to wait its turn.
In the meantime, I'll be looking for or fabricating a steady, overhead pulleys, and some other chuck options.
