For Sale: Brother CNC Machining Center TC-R2B
BROTHERFRANK
Dec 20, 2013
SoCal
Hi all. This productive Brother CNC machine with integrated Quick Table pallet changer and dual full 4th rotary tables is available for sale in San Marcos, CA. It's a 2012 that was installed new in 2013. Original owner. Comes with dual Yukiwa 4th axis trunnion setups. 16.6" x 12.6" X and Y travels respectively. 16K rpm, 6000 rpm Synchronized tapping, Brother B-00 control with 10Mb memory, 2 Mb buffer, USB, Ethernet, High Accuracy mode, dual Blum Znano probes, Work lights, wash gun, mpg. Asking $48K
I was asked if the rotaries could be easily removed and re-installed. I will answer here for everyone's benefit. Yes, each rotary has a short cable with an Amphenol type water proof connector that connects at a central junction box under the center divider sheet metal on the pallet. 6 SHCSs to remove the center divider and access the connectors. One or both rotaries can be removed in about 20 minutes. Also, there is an Outside Index button that allows the rotary on the outer loading position pallet to be indexed to any angle for loading while the inner pallet is machining. So this two sided fixture can be rotated 180 degrees or if a 4 sided fixture was installed, it can index 90 degrees etc...
