M. Roberts
- May 11, 2021
Hello good people, TGIF. Does anyone have advice, knowledge, or experience with dressing a corner radius on a diamond grinding wheel? Details on the wheel: 12" dia. x 2" wide, 100g vitrified bond wheel, the desired corner radius is 0.04". Details on the part and material: part is composed of a SiC based ceramic composite. The part itself is flat; 13.5" diameter x 0.625" thick, with a 0.5" wide x 0.125" deep step around the circumference...the 0.040" radius is on the inside of the step. The thinking is that we could purchase a new Okamoto rotary (the reason for my previous post), grind the top of the part, true the radius (more on that), and kiss the step. The grinder that I am looking at has a single point diamond dresser built located under and behind the wheel, and has the ability to be programmed to perform a true/dress cycle automatically...not sure if it can do a radius though. Great, right? Now the issues...with diamond wheels, by far the best way to true them (that I have found) is by using a truing spindle equipped with a diamond wheel. What I really would like to do is to remove the single point, and install the truing spindle in its place, and when a dressing/truing cycle is called out, the truing spindle kicks on, and the machine does its thing...seem to crazy of an idea? Add some of your own if you like...Thanks, Mark
