Hello guys.
I have just noticed a problem with my FP2. When I move the X axis from one side to the other the Z axis shifts by 0.03mm on the DRO.
I moved it around and put my weight on it to see if it would change and it does not. Does anyone know how I can start troubleshooting this?
The power feed is working fine, I suppose I can try drive the table from end to end without using the power feed and see if the result is the same.
* I edited the title of the thread to Z axis rocking instead of creep, as it was determined below that this is the problem.
