FS - 10" x 27" Gear Head Machine Lathe - like Craftex Lathe
distracted
Mar 18, 2005
Brampton (near Toronto, Canada)
Excellent new condition. Only tested. Planned to convert to CNC, but plans have changed!A slightly larger gear head lathe for the serious hobbyist or the maintenance man who needs a small lathe for specialty repairs. Solid cast iron construction and a 6 speed gear head spindle gives durability and dependable service!
Features:
* Motor: 3/4 HP, 110V, 8.8 Amps (550W per the nameplate) with Reversing Switch
* Spindle Speed: 6 Speed (115 - 1626) RPM
* Gearbox driven by Twin Belt Drive
* Between Centers: 27"
* Swing Over Bed: 10"
* Swing Over Cross Slide: 5"
* Spindle Bore: 1.125” (1.159” measured)
* Head Spindle Taper: MT4
* Inch Threads: 20 ranging from 8-56 TPI
* Metric Threads: 9 ranging from 0.5 - 3.0 mm
* Lead Screw: 7 TPI
* Longitudinal Feed: 0.0025 - 0.005
* Tail Stock: MT2 2" Travel 1-1/4" Offset
* Cross Slide: 4-1/2" Travel
* Maximum Tool Size: 9/16" (0.87” opening)
* Compound: 1" Travel
* Max. Longitudinal Travel of Tool Slide: 3.0"
* Max. Travel of Tail Stock Sleeve: 2.0"
* Dial Reading Units: Inches
Includes:
* 5" - 3 Jaw Chuck c/w 2 sets of jaws)
* Turret Tool Post for up to 1/2" tool size
* Lathe Centers MT4 & MT2
* Tool Kit
Parts appear to be identical to the Craftex 10x18 Lathe B2227 - Buy the Craftex Metal Lathe 18`x 24in from Busy Bee Tools. Busy Bee Tools has Optional Equipment for the 10x18.
* Model B2227LCHUCK - 4 Jaw 5"
* Model B2227LFP - Face Plate
* Model B2227LFR - Follow Rest
* Model B2227LSR - Steady Rest
* Model B2227LCA - Adapter for 4 Jaw Chuck
Asking
