aribert
- Jul 2, 2008
- Metro Detroit, MI
FS - (4) Aloris BXA tool holders and (2) generic import BXA sized tool holders. Holders are not dinged up, these holders appear to have had minimal use or treated kindly. All prices plus shipping. USPS flat rate shipping for 1 to 3 holders in the US is $10. If someone wants to buy more than 3 pcs, I'll need to quote based distance for Regional A (will need your ZIP) vs Medium Flat Rate box at $16.25. PayPal or check (hold shipping till check clears).
BXA-4 Boring 1.0 inch dia w/ 0.75 adapter sleeve $60
BXA-5 #2 Morse Taper, Rust stains on bearing surface to tool post $50
BXA-5c Collet not included, missing the retaining nut $45
BXA-42 Boring 0.75 inch dia This holder is a bit trick - the two bright pads on the bearing surface are spring loaded - when the holder is secured to the tool post the resultant pressure on the pads secures the boring bar / tool in the holder, no idea how well this works, P/N does not show up on Aloris website but I found several images of Aloris -42 tool holders on line. See close up images $70
Import BXA sized Boring, 1.0 inch dia 250-204 $14
Import BXA sized Knurl/Face $14
$225 for all (6) pcs
