imachine909
- May 17, 2010
- South East
See list below for items for sale. Everything new unless says regrind are unused after regrind. PayPal for payment or credit card with a 3% fee. Buy pays shipping for whatever they buy.
REAMERS
MORSE EDP#29262 .1880" DIA 4FL HSS 2PCS $12 FOR BOTH
TAPERED END MILLS
SGS EDP#32488 1/2" DIA X 7 DEG BALL 3FL COATED 4PCS $45 FOR ALL 4
WIDIA EDP#5329122 1/2" DIA X1.07"LOC BALL 2FL 4PCS $45 FOR ALL 4
INSERTS
YG-1 EDP#12000006 APKT160416PDTR YG602 10PCS $20 FOR ALL 10
ISCAR EDP#5506929 T490 LNMT 1306PNTR-CS 830 10PCS $40 FOR ALL 10
DRILLS
WALTER DC150-05-10.761A1-WJ30RE 10.716MM DIA 5XD CARBIDE THROUGHT COOLANT 2OPCS $50 FOR BOTH
YG-1 D4146015 15/16 DIA DRILL HSS 1-5/16LOC TiN COATED 4PCS $12 FOR ALL
YG-1 D4146014 7/32 DIA DRILL HSS 1-1/4LOC TiN COATED 2PCS $6 FOR ALL
GURHING 5.95MM DIA 5XD ROUGHLY TiN COATED NO BOXES 2PCS $6 FOR ALL
YG-1 31/64 DIA 3XD ROUGHLY TiN COATED NO BOXES 5PCS $28 FOR ALL
YG-1 DH424011F 11/64 DIA X 3XD CARBIDE 2PCS $15 FOR BOTH
YG-1 DH423050K 5.0MM DIA X 3XD CARBIDE 1PCS $8
YG-1 DH406058 5.8MM DIA CARBIDE 1PCS $8
YG-1 SPECIAL 6.05MM DIA X 26MM LOC CARBIDE FLAT BOTTOM DRILL! 6PCS $34 FOR ALL 6
YG-1 DH424051K 5.1MM DIA 5XD CARBIDE 2PCS $16 FOR BOTH
END MILLS
HARVEY EDP#23248 3/4 DIA X 270 DEG X .640LOC X 1.5 NECK 4FL UNCOATED LOLLIPOP TOOL 1PCS $25
HELICAL EDP#53242 1/2" DIA X .06CR X .625LOC X 3.375LBS X 6""OAL" 4FL APLUS COATED 1PCS $20
HELICAL EDP#51244 1/2 DIA X .12CR X .625LOC X 2.25LBS X 4""OAL" 5FL APLUS COATED 1PCS $17
ROBB JACK FMHV-303-08-TC 1/2 DIA X SQ CR X 3/8LOC X 1.5LBS X 3"" OAL 3FL UNCOATED THROUGH COOLANT 1PCS $15
IMCO EDP#63098 1/2 DIA X .03CR X 1-1/4 LOC X 3""OAL 4FL ALTINX COATED 1PCS $20
GWS EDP#615215 1/4 DIA X BALL NOSE X 1-1/4LOC X 3" OAL 3FL ZRN COATED 1PCS $12
GWS EDP#1003657-A01 3/8"" DIA X SQ CR X 1.5LOC X 4"OAL 3FL ZRN COATED 1PCS $15
YG-1 JAG97821 3/4"" DIA X .12CR X 1""LOC X 3"" OAL 3FL COATED 1PCS $18
WALTER 25MM DIA MB265-25.0A3X200C-WJ30CA 3FL COATED THROUGH COOLANT 1PCS $42
SPECIALS 1/2"" DIA X .03CR X 1-1/4"" LOC X 3"" OAL"4FL T iALN COATED 20PCS $40 EACH
SPECIALS 1/2"" DIA X SQ CR X 2"" LOC X 4"" OAL" 3FL ZRN COATED 20PCS $45 EACH
SPECIALS .98"" DIA X .04 X 45DEG X 1.65"" LOC X 3.5"" OAL 6FL COATED FOR STEEL 10PCS $34 EACH
SPECIALS 1"" X .04 X 45DEG X 1.65"" LOC X 4"" OAL" 4FL COATED FOR STEEL 10PCS $38 EACH
SPECIALS 3/4"" DIA X .06CR X 1.375 LOC X 4.25 OAL 5FL COATED FOR HARD METAL 15PCS $32 EACH
MELIN EDP#ST1842 1"DIA X .045 CHAMFER X 1.625LOC X 4"" OAL 6FL COATED WITH All4 2PCS $42 EACH
YG-1 UGMH07931 1/2 DIA X .125CR X 5/8LOC X 3-3/8LBS X 6"" OAL" 5FL TITAN NOX 2PCS $62 FOR BOTH
YG-1 SPECIAL 3/4 DIA X CHAMFER CORNER X 1-1/2 LOC X 4"" OAL 4FL V7 PLUS 2PCS $75 FOR BOTH
YG-1 UGMH07967 3/4"" DIA X .250CR X 1-1/8LOC X 3-1/4LBS X 6"" OAL 5FL TITAN NOX 2PCS $85 FOR BOTH
REAMERS
TAPERED END MILLS
INSERTS
DRILLS
END MILLS
