FS: more grinding stuff- silicon carbide face grinding wheels, 6” CBN wheels, Pferd hook and loop, 8” PSA sanding disks and a bunch of other stuff
mattthemuppet
Apr 22, 2016
San Antonio
First up, silicon carbide 90x21x50 (3.5x7/8x2”) face grinding wheels with 5/16” mounting hole. Teiken brand I think. 240, 320, 800 and 1000 grit. $7.50 each new, $10 for the pile of used onesIMG_1480.jpegIMG_1481.jpegIMG_1482.jpegIMG_1483.jpeg
New grinding wheels, $10 each
Norton 6x3/4x1/2 60 grit (2)
Norton CBN ahem, silicon carbide 6x1-1/4x1/2 800 grit (4)
Norton 6x1x1 100 grit
Beuhler CarbiMet 8” silicon carbide sanding disks (100pk) and Metagrip liners (10pk). 400 and 600 grit PSA and 240 grit plain. $40 a box for the sanding disks and $20 for the box of linersIMG_1486.jpegIMG_1487.jpeg
13 Norton 6 x .060 x 1/2 57A541-RB25 Toolroom Non-Reinforced Type 01 Cut-Off Wheel $10 each or $100 the lotIMG_1490.jpeg
10 Leco 10x1/16x1-1/4” cut of wheels, $10 each or $80 the lotIMG_1489.jpeg
20 120 grit and 10 240 grit 1/8” shank flap wheels $10
Mix of new and used 1/4” shank flap wheels and buffing wheels $10
100 little wire wheels 1.5x1/4x1/2 $20
80 Misumi soft polishing stones 1/8” shank $10
100 pink grinding stones on 1/4” shanks $20
1-1/4” RH grinding wheel adapter $25
10 Roloc sanding pads $10
5 new and 3 used Roloc 120 grit sanding disks $5
Pferd hook and loop, 23 disks and pads and two adapters, all new $30 the lotIMG_1461.jpeg
24 new grinding wheels and 6 cut off disks, plus some used stuff $25 the lotIMG_1464.jpeg
Matt,
I'll take one each of these 240, 320, 800 and 1000 grit. $7.50 ea.
Changed my mind, make it the stack of used ones for $10. And one of these.
Norton CBN 6x1-1/4x1/2 800 grit
Ken
I'll take:
  1. One of each grit of the small SiC wheels
  2. One of the CBN 800 grit wheels (even if not CBN)
  3. The 1 1/4 wheel adapter
  4. Some of your other stuff you've posted in other threads. Go ahead and start a pile for me for now
I can do these:
100 little wide wheels 1.5x1/4x1/2 $20
and these:
