FS - new carbide! Solid and through coolant drills SAE and metric, chamfer mills, lollipop mills, corner rounding endmills and reamers
mattthemuppet
Apr 22, 2016
San Antonio
This is going to take a little while :)
New solid carbide drills: $2-3 each for 1/8" and under, $5 from there to 1/4", $10 from there to 3/8" and $20 above that.
List of fractional
5/64
3/32
Four 9/64
Two 3/16
Five 13/64
7/32
15/64
17/64 flat end
11/32
25/64
29/64
31/64 (not sure if this is unused but it is in excellent condition)IMG20230708182329.jpgIMG20230708182336.jpgIMG20230708182348.jpgIMG20230708182403.jpg
List of number drills
5
7
9
Three 29
Three 36
42
50
51
New fractional through coolant: $5 1/8", $10 up to and including 1/4", $15 up to and including 3/8", $20 up to add including 1/2" and $30 above that.
One 1/8" Guhring and seven extended 1/8" Gulf Coast Tool
Two 7/32, one Gulf Coast Tool and one Mitsubishi
Garr 17/64
Guhring 11/32
Mitsubishi 7/16
Two PCT 31/64
Two Garr 9/16
Two Garr 19/32IMG20230711175637.jpgIMG20230711175656.jpgIMG20230711175706.jpgIMG20230711175730.jpgIMG20230711175740.jpgIMG20230711175746.jpgIMG20230711175752.jpgIMG20230711175800.jpgIMG20230711175809.jpgIMG20230711175814.jpg
Metric through coolant, same prices as SAE through coolant
Kennametal 5.41mm
Mitsubishi 5.50mm
Mitsubishi 6.10mm
Mitsubishi 6.30mm
Mitsubishi 6.50mm flat end
YG1 8.9mmIMG20230711182403.jpgIMG20230711182410.jpgIMG20230711182426.jpgIMG20230711182430.jpgIMG20230711182439.jpgIMG20230711182448.jpgIMG20230711182455.jpgIMG20230711182514.jpgIMG20230711182638.jpg
Five 1/2" Harvey Tool lollipop mills, $10 ea or $40 for all five
Corner rounding endmills (one on the left has gone)
0.125rad, 3/8" shank Harvey Tool
0.12"rad x 45deg 5/16" shank
Three Guhring 5/16" which look like the 5/16" one above. $10 each or $40 for the lotIMG20230705140829.jpgIMG20230705140853.jpgIMG20230705140902.jpgIMG20230705140913.jpg
New and like new chamfer mills
3/16 x 10deg $3
0.360 x 30deg, not sure if this has been used, but it fits have a flat ground on the shank $5
Two 0.343 x 40deg $15ea
Two 0.340 x 40deg $15ea
Two 3/8 x 20 used but excellent condition $15 the pair
Two 1/2 x 12deg $20ea
1/2 x 40deg $20
Matt, please add this list and I will put a 2nd check in the same envelope to you.
Please no through coolant drills, add this to #7 #42; Fraction (2each) 9/64" (1ea) 3/32" & (1ea)13/64" plus
Garr 3mm
Guhring 3mm
Guhring 3.3mm
YG1 3.5mm
I think 11 total drills, all small in diameter. If I have taken too long and something someone else got, say so. Many thanks!!
Garr 3mm
Guhring 3mm
Guhring 3.3mm
YG1 3.5mm
Sorry Chris, Paul claimed the 3/32 already. The rest are yours though, thanks! I'll get you and Paul totals in the morning, I'm pooped for the night.
Solid carbide reamers, same prices as the solid carbide drills
Three 0.083
0.1403
Two 0.1505
Two 0.214
Two 0.2625
0.2800
0.298
Three 0.308
Two 0.314
0.3459IMG20230712122647.jpgIMG20230712122659.jpgIMG20230712122711.jpgIMG20230712122731.jpgIMG20230712122756.jpgIMG20230712122802.jpgIMG20230712122808.jpgIMG20230712122813.jpgIMG20230712122824.jpgIMG20230712122835.jpg
