G68 Rotation
csharp
Sep 24, 2009
PA
When using a G68 to rotate the coordinate system do I need to cancel it before changing work planes (G17,G18,G19)?
I assumed I need to call out the work plane before the rotation command so we know what axis to rotate around but then once the rotation is set I could call up other work planes???
Thank you
Correct. The code is G69 to cancel. I turn it on and off for each tool to make sure I can visually verify at the start and end of each tool.
