Grabbing cut wrench flats with sub spindle
Dicks4fingers
Dec 24, 2019
I have a part where I'm cutting in a hex for wrench flats with live tooling. I want to grab the wrench flats in the sub spindle with flat faced jaws and cut the other side. I made it so I should have been able to sync things up with flats ar 33.33 degrees but when I hand off while using g199r33.333 it is always slightly off and puts awful marks into the part. I can't figure out how to get it lined up correctly. The wrench flats were cut using y axis not c axis movement.
