Gummed up Micronizer lubricator cleanout?
richard newman
Jul 28, 2006
rochester, ny
The thread about using vegetable oils for cutting oil reminded me that the Micronizer lubricator I use for resawing wood on my bandsaw is all gummed up after sitting around for 10 yrs. I can't even remove the reservoir. Pretty sure it was a vegetable based fluid in there.
Any suggestions on what I could soak it in that would do minimal damage to seals, but still loosen up the old oil?
Try WD40. It is good for doing so many things.
Roger
Gordon --
The first-generation of granulated drain cleaners were a blend of lye and aluminum granules. The aluminum reacted with the dissolved lye, to the point that the solution would sometimes boil and "geyser" from the pipe.
I don't know if anyone is still marketing a lye-and-aluminum granulated drain cleaner in the US.
I didn't know that. As a kid I used to use crystal Drano, aluminum foil and water in a Pepsi bottle to make hydrogen balloons, but I had no idea there was alu already in there. Couldn't see it.
