evotechcorp
- Sep 16, 2019
Just installed a WIPS system on my mill with classic control and having issues with the calibration cycle. I've tested the table and spindle probes and both of them are registering at the console with the audible beep as per the install manual. When I start the table probe calibration the OMI is not turning on (assuming it should be automatically turning on when a probe cycle is run). If I manually turn on the probe in MDI mode and run the calibration the Z axis returns to zero and I get an alarm 1000 which doesn't exist - alarm text states "alarm text not found" I've cleared macros, work and tool offsets and continue to get the same results. I'm wondering if the 9000 programs on my system are not the V3.0 that are required, not sure how to find out the loaded version. It's the same as what came on the backup USB. Hoping maybe someone has some insight?
