Haas UMC 500 alternatives
updatedsecurity
Jun 6, 2021
Hello
I am in the market for a relatively affordable 5 axis machine. So far the UMC 500 at around 147 k is coming in as the most affordable. What else is out there. The other option for us is the okuma Genos 560 with a trunion at around 180k. I know they are completely different machines. I like the haas because it's cheap and has a bigger envelope for 5 axis than an okuma. I like the okuma because I can sometimes remove the trunion and cut bigger parts, though the 5 axis on it is small. About us. We do a little bit of everything. Mostly pretty work rather than high tolerance work
Stirling
Dec 11, 2013
Alberta canada
I’ve heard a trunnion on a haas vertical has better accuracy than the umc series.
Mind you they have that new umc350. That looks interesting(ish)
Or a haas Tm with a trunnion would be the cheapest….
Not knowing what your part size/tolerance is makes it awfully hard to make any recommendations tho,
updatedsecurity
Jun 6, 2021
From what I hear, due to thermal growth issues, a UMC-500 is a .005" machine. You'd probably get tighter tolerances putting a trunnion on a VF or VM.
I think we can work with this. Would you know of other machines in that space? Haas can't be the only one. With a trunion haas there would be less space for the 5 axis work and the costs would be similar. At least from what I saw on their site
updatedsecurity
Jun 6, 2021
Hello.
Parts are all over the place. All are not very high tolerance. Mainly aluminum. Biggest part is about 17x2.5x1.5 inches. I could possibly squeeze it into a umc500. Mostly I want the machine for positioning to reduce setups
mhajicek
May 11, 2017
Minneapolis, MN, USA
I made Titanium orthopedic plates and other medical device parts on a VF-3SS with a trunnion for six years, and I was fairly pleased with the machine. Thermal growth in Z was about a thou; X and Y stayed within .0002". I have a client who is seriously considering an Okuma; we checked them out together, and they look like very solid machines. Not quite to the level of Hermle, but there's a price difference proportional to that.
If you need to swing a 17" + part, you could always use one of these:
One thing I really like about the Haas VMC with an add-on rotary, is you can change things up. I'll spend most of the time with no rotary, a little time with the fourth axis, and once in a while put the fifth axis on, depending on what the job demands. Just power down, swap the plugs, start up, change some settings, and reboot again. Takes about 15 minutes, not including mechanically aligning the rotary.
gregormarwick
Feb 7, 2007
Aberdeen, UK
Not any kind of recommendation for this thread specifically, but this is one of the things I liked about the Hurcos. There is nothing to change, as they will reconfigure themselves automatically at startup depending on whether the rotaries are plugged in or not.
Areo Defense
Apr 25, 2022
We have a number of UMC 500SS's and they're decent for the money, especially given how user friendly the control is. Our most recent 500SS is equipped with the 20+1 pallet pool with fixturing for dovetailed blanks and there is also a 10+1 pool with larger pallets available. We hold within .001 all day long cutting aerospace and defense parts. I haven't looked at other machines in that class so I have no comment there. If you need a pallet pool, the 500 is a decent machine. As others have said, if you need the flexibility then you might go with a vertical + trunnion. Another similar setup, if your parts are smallish, is a TRT for 5-axis and keep some table room open for vises.
updatedsecurity
Jun 6, 2021
Hello
Thank you. I am getting this priced out as well. I have an older vf2 with a rotary so hopefully if we go this way I can get it running faster.
gregormarwick
Feb 7, 2007
Aberdeen, UK
I might as well ask. Are there Chinese or taiwanese machines I should look at?
Yes, and I'd take any of these over the Haas even if they were more expensive.
Disclaimer: I do not have experience with these machines directly, only the MTB.
https://www.victortaichung.com/machine-tools/en/Vcenter-AX630.html - bigger than the UMC 500, but their next smaller machine is a C frame machine
https://www.quaser.com/products/detail-26 - pretty comparable size-wise to the UMC 500
No experience of my own with this MTB, but I'm told they're good:
Vancbiker
Jan 5, 2014
Vancouver, WA. USA
How about this?
Thought the OP was looking for competition to a UMC500, not a machine you can fit one into.
