Haas VF2SS/SURFCAM post processor?
Neon Theorist
Apr 22, 2019
Any of you more enlightened folk see any issues with this Mpost?
Or am I gtg?
name HAAS X
% 00
/ 00
O 4
N 4
G 2
g >2 G
X ->3.>4
Y ->3.>4
Z ->3.>4
I ->3.>4
J ->3.>4
K ->3.>4
Q ->3.>4
R ->3.>4
P >40
F >3.1
H >2
D >2
T >2
M >2
S >4
SbackDoor SupressHeader
ModalLetters X Y Z F # List of letters that are modal
ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 85 # List of g codes that are modal
Sequence#s N 0 1 1 # Char, freq, incr & start
First#? N # Y or N 'Output 1st sequence no.
Last#? N # Y or N 'Output last sequence no.
HCode X # X or X U 'Horizontal char.
VCode Y # Y or Y V 'Vertical char.
Dcode Z # Depth char.
FeedCode F # Feed rate char.
Comment ( ) # Begin End comment char.
Spindle 3 4 5 # Cw, ccw & stop m codes
Coolant 8 9 7 61 62 63 64 # Flood, Off, Mist and Thru Spindle M codes
DComp 41 42 40 # Left, Right & Cancel m codes
LComp 43 49 # On & Off codes
Feed G01 # Linear move
Rapid G00 # Rapid positioning word
ArcPlane G 17 18 19 # G17, G18, G17 Arc Plane selection
ReturnPlane 98 99 # G98 G99 Return Plane selection
Cw G2 # Circular move clockwise
Ccw G3 # Circular move counter clockwise
Inc/Abs G 91 90 # Inc & Abs char. & values
CtrCode I J K # I J or R or I J K L
Helical? Y
Spaces? Y # Y or N 'Spaces between words
Incremental? N # Y or N 'Inc or abs output
CtrIncremental? Y # Y or N 'Inc or abs I & J
ByQuadrants? N # Y or N 'Break arcs at quadrants
UppercaseComments? Y # Y or N 'Require uppercase comments
Drill # Drilling canned/manual cycle
G81 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
CSink
G82 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] P[Dwell]
end cancel
Peck # Pecking canned/manual cycle
G83 G[RetPlane] X[H] Y[V] Z[D] Q[VBite] R[Vclear] F[FRate]
end cancel
Tap # Tapping canned/manual cycle
G84 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[Frate] Q[VBite]
end cancel
LTap # Left handed tapping cycle
G74 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Ream # Reaming canned/manual cycle
G85 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Bore # Boring canned/manual cycle
G86 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Back # Back boring canned/manual cycle
G87 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Cancel # Cancel a canned/manual cycle
G80
end
StartCode # Start of the program
%0
O[0]
G17 G40 G80 G90
End
1stToolChange # First tool change
T[Tool] M6
M[Direct] S[Speed]
G0 G90 G[54] X[H] Y[V]
G43 Z[D] H[Lcomp] M[Cool]
End
Infeed # Enable cutter comp
G[Side] X[H] Y[V] D[DComp] F[FRate]
end
Outfeed # Disable cutter comp
G1 G40 X[H] Y[V]
Z[D]
end
ToolChange # Secondary tool changes
G0 G49 Z0 M9
T[Tool] M6
G0 G90 G[54] X[H] Y[V] S[Speed] M[Direct]
End
Upon [Speed] # Output spindle speed change
M[Direct] S[Speed]
End
EndCode # End of the program
M9
G28 g91 Z0
Y0
M30
%0
End
It'll probably be fine for basic stuff. If you use TSC or air blast, etc. you'll have to modify things so it uses the proper coolant off-code for those.
and there's no rapidcode section? Without it'll probably just go point to point. Some of the generic posts should have something in there if you want a little more peace of mind, like if your next Z is higher, it'll move up first, then XY, and if next Z is lower, it'll move XY first, then Z, etc. Just preference I guess.
If you use positive tool length offsets you'll want to change G0 G49 Z0 M9 in your toolchange sequence.. otherwise you'll have a bad day. Or use G0 G90 G49 G53 Z0
Thanks for the feedback friend. All my length offsets are minus, so no worries there I hope.
'Rapidcode" intrigues me. What would that section look like?
Is this it?
I'm 50% certain I didn't have this in my post on my cooked computer.
"RapidCode #(Include 'Z safety' logic)
Comments
IF [D] < [LastD] #Going down?
G0 X[H] Y[V] #XY first,
Z[D] #then Z.
exit
ENDIF
IF [D] > [LastD] #Going up?
G0 Z[D] # Z first,
X[H] Y[V] # then XY.
exit
ENDIF
END"
