Chips Everywhere
- Apr 29, 2021
Up For Sale, local to me, Brooklyn, NY 11211. I'm not the seller, I just make a couple bucks if I help with the sale. PM for contact info.
Copy and paste from the ad:
Up for sale is a Hardinge HLV lathe. Came from an aerospace company that used it for making pin gauges.
We used it to make 5mm aluminum pins that we now make on a CNC lathe, so we no longer have no use for it since we have another manual lathe.
It's well tooled and functions like it should.
The only thing that may need a little work is the cross slide feed, it's starting to slip, can use some adjustment.
220v 3ph
Features:
-Hardinge quick change 4° taper spindle
-0-3000rpm, variable speed adjustment
-Inch gear box, can cut metric threads with additional metric gears
-MT2 tailstock taper
-5C collect closer
-Variable speed apron feed
-coolant pump and chip tray
Tooling:
-Hardinge 3 jaw chuck 5in
-Hardinge 4 jaw chuck 5in
-Hardinge 4 station Turret
-Hardinge steady rest
-Hardinge vertical slide (vertical cut off)
-Hardinge spindle nose protector
-Quick change tool post
-Live center
-Tailstock drill chuck
-Hardinge face plate
-Hardinge quick action lever slide
Asking $10,650 or best reasonable offer. Need the shop space, so make an offer. Guy on the corner can load it with a forklift for $100 onto your truck.
220v 3ph
Features:
-5C collect closer
Tooling:
-Live center
