Mark Rand
- Jul 9, 2007
- UK Rugby Warwickshire
It's probably a left hand thread!
Definitely not a LH thread. I can see the threads. Appreciate the thought, though.It's probably a left hand thread!
That’s a great idea, Bob! I’ll give it a shot and report back. Regarding the scoring marks from my previous attempt, any cause for concern? File off the the burrs and move on?you can try this:
Put a wheel adapter and nut on the nose.
Put a 6 point socket on the nut and attach to a breaker bar. Use this to hold onto the shaft.
Just checked the one in pieces on the bench. Yes, right hands threads.
Bob
Bob for the win!!! I had to make a custom spanner wrench, but I was able to get the Spindle Shaft Bearing Nut off. As always, appreciate the help from y’all. What a great group!That’s a great idea, Bob! I’ll give it a shot and report back. Regarding the scoring marks from my previous attempt, any cause for concern? File off the the burrs and move on?
Thanks!
Jeff
Appreciate it. I’m enjoying it, and I’m hoping I can get everything working well and making parts soon!Thanks for the pics and documenting this. Nice job and good luck!
There is no adjusting the preload on this spindle. It is built into the front bearing pair.Did you find getting the preload correct particularly difficult?
I guess the 'wavy washers' are the only 'pre-load' then?There is no adjusting the preload on this spindle. It is built into the front bearing pair.
You want L. This is standard on a precision pair if no callout.
Lower class bearings need not apply for this job. Fafinir precision 2MM also the same and can be found on the e-yuk and surplus market.
The "rules" call for ultra-filtered grease in this bearing class but one can get away with a lot.
Do not "hand pack" or overfill the bearings. Use a syringe and the correct number of ccs.
To get inside and do this you need to remove the motor. Mark the coupling from motor to shaft and put all things back in the same orients.
The motor was balanced with the spindle assembly attached.
It is a very super easy grinding spindle to rebuild. Certainly more fussy than a B-port but not bad.
Clean, stone, clean more and be nice to it.
Bob
So one can use two wrenches with one in the front and one in the back of the wheel mount if having difficulty removing the spindle nut or the flange nut. Some guys use two wrenches on a regular base.A standard sopko wheel wrench fits in the holes on the back of the adapter.
Notice
