Bill D
- Apr 1, 2004
- Modesto, CA USA
I have a Harrison M300 lathe with what I think is a sheared woodruff key on the apron handwheel. I have disconnected the leadscrew and drive shaft(wrong term)before to drop the apron to clean the inside. They have tapered ends that friction fit into the threading gearbox. Just turn the apron handwheel and they pop out. I think I locked the half nut before forcing it apart. Of course I removed the bearing at the right hand end of he bed first.
The problem is the apron handwheel just spins and nothing moves. So I will have to lever the joint apart somehow. I am open to suggestions. It is not the handwheel being set in the free wheel position. When threading the wheel will turn like it should but touch it and rotation stops. It feels like it is spinning on the shaft.
Bill
ignore red circle on attached image. I do not understand the free wheel aspect maybe the sheared key is outside the apron. Just remembered the DPO broke the handwheel and brazed the spokes back on. years ago.
Bill
