Ironcross44
- Jul 27, 2022
Apologies if this has been discussed (new here)
I have a nice SB Heavy 10 precision I just got, formerly owned by NASA. Its set up with a 1hp 3ph 220vac motor, 3.1 FLA. My question is, if I should use a VFD or rotary phase converter to power it, because I’d still like to change the belt setup to adjust spindle speed and not a dial or digital interface. I have easy access to both 220 (1ph) and 120.
I would think a VFD would work if I just kept the frequency set at 60Hz? Cost isnt too much of an issue, I just like to run these as close to as they were setup to be without modification to the machine itself (ie putting a single phase motor on). This is my first 3ph machine.
Any help is greatly appreciated.
