Control Techniques Quantum III on the Chiron and Mentor series on the grinder which has FANUC DC spindle motor.
Both bought as NOS on E-yuck for a touch over $1000 each.
These drives are just plain great.
Will talk to just about anything, have all the nice stuff like field weakening, field shut off so the motor does not get warm when setting idle, tons of protection, nice on motor brushes, detailed diagnostics on a connected laptop, and will run all by themselves with no connection to the cnc control if desired.
Expensive but worth every penny.
Super configurable and once you commission one of these you'll never want to deal with the lower cost stuff again.
In the past I've built my own from super high power servo amps, done my own field and interlock and added logic as needed. A good learning but wasted a lot of time.
Bob
Thank you Bob. You are giving me a sanity check, as is Vancbiker.
This machine was designed in 1979 and built in 1981. Logic control, switching, memory and even simple AC/DC equipment has been exponentially advanced, and am having an internal battle about repairing in situ again, or upgrading. The internal BUBBLE memory is 19kB, it's a bit cumbersome to drip feed, or DNC etc. Modern PC's don't use printer parallel ports, or even rs232 for decades, so even that nuisance becomes non-existent. Often use rs232/USB cables and in my racing side of the industry, can't tell you how many times those converters fail - at the worst times ..... EVER. FTDI clone chips and firmware was a nightmare not long ago.
Anyone have any experience with Emerson drives? Looks to be very similar for interface as you describe, Bob. This motor is 6hp, and needs 32amp max, 200vdc, which is over many 5hp drives. Must bump up to 7.5 units and the prices jump significant when going over "5hp" and/or 25amp.
$1000 and a weekend of installing/interfacing is a mighty strong candidate for this repair.
Right now, the options are: used/working complete 6M DC spindle drive, with top board included, for $3k, another used board at $1200-2000, reman my board that has loose guesstimates at $2200, or go ahead and use newer equipment (?$?$). Years ago, took a weekend and de/re-soldered all the resistors/rectifiers/regulators/capacitors, tested/replaced all of them for the spindle drive, then one of the "RVxx" FANUC-proprietary Ic's went out a couple years after.
