I am reassembling the headstock of a SB 9B lathe and was using an apparatus to press the spindle into place. It did not work. So I decided to see if the bull gear would fit on the spindle by hand outside the headstock. I found that the key barely fit into the keyway on the bull gear. I could not get the key all the way into the keyway. Now the bull gear is stuck on the spindle. I was following the instructions in the Guide to Renovating the South Bend Late step 107. I also saw several YouTube videos on how to remove/install the spindle into the headstock. In the videos, the bull gear appeared to easily slide on the spindle and the key fits in the keyway. My bull gear does not do so. I would appreciate recommendations on how to remove the stuck bull gear from the spindle. Thanks from a newbie.
Joe
Joe
